Panamera S 2013 Brake Rotor Specs
Hi.. does anyone know the new rotor specs (front and rear) and what the minimum thicknes is for 2013 Panamera S (V8)? Thanks!
for anyone interested here is the answer
Fitting Position: Front Axle
Diameter: 360 mm
Brake Disc Type: Vented
Brake Disc Thickness: 36 mm
Minimum thickness: 34 mm
Fitting Position: Rear Axle
Diameter: 330 mm
Brake Disc Type: Internally Vented
Brake Disc Thickness: 28 mm
Minimum thickness: 26 mm
Diameter: 360 mm
Diameter: 330 mm
