Can brake pads on 996 be changed without bleeding?
Old 02-04-2017, 07:28 PM
Le Porsche
4th Gear
Le Porsche's Avatar
Default Can brake pads on 996 be changed without bleeding?
Hi All,
I'm looking to save some $$$ on replacing my front brake pads on 996 C4S 02' so doing it myself. I have the new pads and sensors and changing them over is straight forward. My question, which I have not been able to locate in the threads - "Is it ok to swap the pads over without bleeding the brakes?
Thanks in advance for the advice!
Nick
Old 02-07-2017, 06:14 PM
Le Porsche
4th Gear
Le Porsche's Avatar
Can anyone provide me with an answer on this??
Old 02-07-2017, 06:17 PM
LexVan
LexVan's Avatar
Received 5,388 Likes on 2,509 Posts
Your brake fluid should be flushed every 2 years. When was the last service?
Old 02-07-2017, 06:20 PM
Turbodan
Turbodan's Avatar
the answer is yes.
be sure to remove cover of master cylinder before compressing the calipers to get the pads out. not a bad idea to put a rag around the master cylinder.
As lex said you should swap out the fluid every track event or every other year. for $50 you can get a motul bleeder system which makes the whole fluid swap very easy to do without an assistant.
Old 02-07-2017, 06:26 PM
Le Porsche
4th Gear
Le Porsche's Avatar
Hi Guys,
Thanks for the advice. It needs the flush done but pads are really low so wanted to get the new ones in now and do the flush and bleed later. Will grab one of the bleeder systems.
Cheers guys!
Quick Reply: Can brake pads on 996 be changed without bleeding?
