First time replacing rear pads, questions? - Page 2 - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 02-07-2006, 05:52 PM   #16
ronone10
User
ronone10's Avatar
Jim, I see now. So now I understand why others have commented about it breaking off.
thanks...
ronone10 is offline
Old 02-08-2006, 02:47 AM   #17
Bill Wagner
Bill Wagner's Avatar
Ron M wrote:
Quote:
Bill, the high temp brake grease I imagine you can buy it from most auto parts stores. Is it specific for brake pads or for other uses? Any particular brand?
Ron:
The stuff I got is sold in little packets and is widely available and is called "AGS Sil-GLYDE BRAKE LUBRICANT." If you put it on the edges of the pads, make sure you put it ONLY on the metal portion with a very light coat, otherwise a small amount will eventually end up working it's way onto the rotor. When you look at the pad it will be clear what i mean.
Now about the brake pad sensors. The fronts and rears look alike until you compare their lengths. The plastic in the area that fits into the notches on the pads is VERY brittle and easy to break. DON'T FORCE THEM, or you'll end up busting them (learned that the hard way). After busting one of these I did a preliminary fit (without pushing the sensors in place) to make sure they'd fit and then filed the notch area on the pad a little when needed to make sure they went in OK. I ordered 3 of the front sensors and 3 of the rear, and guess what...none are left.
A lot of people just don't bother with the sensors and instead cut the old wires sensor about an inch from where it comes out of it's connector, strip the wires, solder them together, and then put heat shrink tubing over them. All the sensor is, is a wire embedded in the plastic tab that fits into the brake pad. When the brakes wear down, they effectively "sand down" the surface of the sensors and eventually cause the little wire to break. This causes what was a completed circuit to become an open circuit and then the brake pad wear iights on the console go off.
I gave serious thought to shorting the connector and just leaving the sensors out, but I figure that I'll get about 40K - 50K miles out of the pads, which to me translates to about 7 years of use, and I would wonder if I'll really keep the car that long. A future buyer may see this as sloppy work, and a PPI may indicate that it's a job that needs to be done thus lowering the value of the car a little.
Hope this helps,
Bill Wagner is offline
Old 02-08-2006, 03:20 PM   #18
ronone10
User
ronone10's Avatar
Bill,
Thanks again for the detail information. I didn't order extra pad sensors and may consider the bypass method if they break. Good point about the resale of the car.
Looking forward to getting my hands dirty this weekend....
ronone10 is offline
Old 02-08-2006, 04:00 PM   #19
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Quote:
But if you just solder the ends of wire together, it is a 15 minute job to reverse this and put in sensors before selling.
Marc
Marc Shaw is offline
Old 02-09-2006, 02:31 AM   #20
Bill Wagner
That's true, Mark.....but in my case I would be doing this about, oh...say 4 or 5 years from now.....now, if i can ONLY REMEMBER where i put those sensors....
Related Topics
Thread Thread Starter Forum Replies Last Post
How to: Rebuild brake calipers (with video) neil_b Boxster & Boxster S (986) Forum 0 05-03-2016 01:43 PM
Front piston came out of boot, can't get it back in, do I need the boot to be on? Mister Quickie 924/931/944/951/968 Forum 3 03-26-2016 09:01 PM
Caliper Rebuild Thoughts/Observations rodneyr 996 GT2/GT3 Forum 2 01-02-2016 03:38 PM
DIY 997.1 base brake pad replacement lisnter 997 Forum 4 12-10-2015 11:06 PM
PCCB brake pad change notes and questions ILLCOMM 997 GT2/GT3 Forum 9 04-01-2013 10:14 PM
Tags
2002, 993, brake, change, clip, dodge, pacifica, pad, pads, ram, rear, remove, replace, seattle, silglyde, step
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
