Oil Change on Cayenne Diesel ( 2013 ) - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 03-18-2017, 07:39 PM   #1
aussie_bob
aussie_bob's Avatar
Default Oil Change on Cayenne Diesel ( 2013 )
When changing the oil for the first time I had difficulty getting the top off the oil filter enclosure thinking it was tending to twist with the torque and noticed the yellow bracket missing in the attachment . I assume it is in the Alldatadiy.com diagram but not include during assembly ... Does anyone know about it ? After I got a 32 mm socket I was able to get the top off the filter enclosure to replace the filter element and "O" ring .
Only issue I have an oil "seep" from the drain plug which I still need to resolve. The plug kit came with a new plug and copper crush washer but the original crush washer was a traditional crush washer not a solid washer ....any comments on that ?
aussie_bob is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Oil Filters for 996 turbo bobs95 Parts Marketplace 2 12-01-2016 03:19 AM
928s4 oil plug crush washer size? johnu 928 Forum 4 11-01-2016 04:45 PM
Macan oil change question 993BillW Porsche Macan 14 01-25-2015 11:05 AM
Fixed - Help - Oil leak Drain Plug SanDiego928 928 Forum 24 09-17-2011 08:18 AM
Oil Change Procedure DIY wsybert 964 (1989 - 1994 911) 0 04-01-2007 01:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
  • Ask a Question
What's your question?
Send
