Remote Key Fob Programming made Easy REVISED! - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 06-07-2012, 04:52 PM   #1
pp000830
Shade Tree Fixer
pp000830's Avatar
Default Remote Key Fob Programming made Easy REVISED!
Dear Rennlisters,
This posting updates and replaces the similar postings in the DIY ARCHIVE and 993 Technical Web Forum:
Attached is an easy to follow step by step chart to deactivate the ignition
immobilizer and add remote key fobs to your 1995 on 993 (up to 4 fobs total).
It makes the process easier to follow when you are in the car actually going
through the process.
I recently updated the form by adding setup steps to the beginning of the form and notes at the end on how to do the process.
-fill in your cars immobilizer code digits on Setup Steps 3 through 6 and
-keep the form in a safe place for an emergency.
As always use my posting information at your own risk!
Andy
pp000830 is offline   Reply With Quote
Old 06-10-2015, 09:04 PM   #2
pp000830
Shade Tree Fixer
pp000830's Avatar
New Revision:
Old 05-13-2016, 11:50 AM   #3
pp000830
Shade Tree Fixer
pp000830's Avatar
Default Update
Minor revision of notes:
Related Topics
Thread Thread Starter Forum Replies Last Post
Remote Entry Key Fob Programming Made Easy (updated Form) pp000830 993 Forum 36 11-28-2016 12:21 PM
Remote Key Fob Programming made Easy Revised! pp000830 993 Forum 15 05-13-2016 04:58 PM
Updated Programming Key Fob /Switchblade Key Version 9 pp000830 993 Forum 52 05-13-2016 11:53 AM
993 fob / immobilizer issue Scrumpy 993 Forum 31 01-22-2016 01:30 PM
My first two projects: installing venture shield and programming 993 key fob remotes SeaJeff 993 Forum 4 03-06-2011 09:18 PM
Tags
07, 2004, 2007, 993, cayenne, cayman, fob, forum, hummer, key, keyfob, made, porsche, procedure, program, programming, remote, setup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 1998 - 2015 Rennlist.com
  • Ask a Question
What's your question?
Send
