Square Dash 944 Erractic Idle solution
Old 04-19-2011, 06:56 PM
massive
massive's Avatar
Default Square Dash 944 Erractic Idle solution
Here's a checklist procedure I've used on two separate occasions to solve an erratic idle on my early 944 (Square Dash 1984 model) http://944foot2thefloor.blogspot.com...44-square.html This is not the only solution to this problem as it can be caused by lots of things, namely vacuum leaks but that was not the case in my situation.
massive is offline
Quick Reply: Square Dash 944 Erractic Idle solution
