944 Front Wheel Speed sensor
Old 01-28-2017, 09:31 PM
gregturek
gregturek's Avatar
Default 944 Front Wheel Speed sensor
Apologizes if this has been cover previously, I wasn't able to find it.
Does anyone have a easy and/or clean solution for picking up front wheel speeds of a 944/968? Tapping the ABS sensors is tempting, but I don't want to impact the functioning of the brakes in any way.
Thanks,
Greg
Old 01-28-2017, 10:46 PM
car_slave
car_slave's Avatar
Pin 17 off the ABS computer should supply you with a speedo signal. Don't tap the sensor itself.
Old 01-28-2017, 10:51 PM
gregturek
gregturek's Avatar
Thanks. But I'm looking for individual wheel speed sensors. Do you know if that is a particular wheel?
I have the GPS speed and one rear wheel speed sensor, but the fronts are a little harder to install a sensor.
I'll dig a little deeper into the ABS pin outs!
I appreciate your help!
Greg
Old 01-29-2017, 12:17 AM
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Matt Romanowski's Avatar
You should be able to do something like this at the front. This is off my 914 (911 is the same), but the hubs are similar. We made a little bracket to go from the brake shield mount hole to hold the sensor so it could trigger off the wheel stud heads. The rear is harder to do, but you can put a ring on the CV joints or rig up some other way.
I can help you out with the sensors if you need to buy them.
Old 01-29-2017, 11:00 AM
gregturek
gregturek's Avatar
Thanks Matt!
I never thought about using the heads of the wheel studs. Great idea.
We have one rear wheel speed sensor. With the CVs it was a little more obvious how to pick up wheel speed.
Thanks,
Greg
Quick Reply: 944 Front Wheel Speed sensor
