Tracking sector data
Ok, I'm still going through withdrawals knowing Sunday was my last track day of the year. So I've started combing back though all of my data. While I'm looking for best line, braking locations, coasting etc., I'm also wanting to create a baseline cheat sheet by sector. I'm compiling a list of the best value I have, by sector, of each of the following information:
â—‹ Fastest Time
â—‹ Max Speed
â—‹ Min Speed
â—‹ Min Distance
â—‹ Max Gsum
I know min distance may eventually need a "target distance" instead but right now it's at least a baseline of some sort.
Is this stupid? Is this the right information? Do I need to get a life?
â—‹ Fastest Time
â—‹ Max Speed
â—‹ Min Speed
â—‹ Min Distance
â—‹ Max Gsum
Basic Site Sponsor
Basic Site Sponsor
Received 2,801 Likes
You need to get a life! Hahaha!
To start, pick three. Distance is a cool measure comparison, but GSum is far more valuable.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Basic Site Sponsor
Basic Site Sponsor
Of all, vMin and duration thereof, has the greater single impact on lap times.
If you really have a lot of time on your hands and have video, stitch together from the various sectors a video with your best theoretical lap based on fasters sector times.
Rennlist Hoonigan
which cost no drachmas
I would say you have good priorities in your life, as they are not too dis-similar to mine after the kids are in bed instead of watching tv.
I would first focus on minimum time as that is really what we're after. Then I would probably look at max average Gsum, then max speed, then min speed. All the other measures will contribute to the min time, so they are good supporting material.
You will also have to look at the line traveled to see if the various segments can be put together. You have to watch that you maximizing the best corners.
Originally Posted by Frank 993 C4S
stitch together your best theoretical lap based on fasters sector times.
My ideal lap from all sessions is .7 seconds below my PB. Inside of the sectors, there are a few times where I gained more than that but gave it back. I need to figure out if it was possible to keep the gains or not.
Also, my max GSum is 1.44 on any sector. But I'm only hitting that in 2 sectors. 3 sectors are maxing in the 1.3s and one is in the 1.2's. So I think I can obviously be carrying more speed through these.
Rennlist Hoonigan
If you have an AiM system, you could create a math channel with the GPS Elevation channel to give you a reference to see if the topography is causing a change in the G force. Same for camber.
Basic Site Sponsor
Basic Site Sponsor
Have you done that yet, Matt? I tried it and the GPS Elevation information wasn't consistent enough to get the variance of the topography into the measure. I suppose you could gate it...
I have used the gSum measure for a long time as a gauge of total tire grip use. Usually a colored map is the most useful way to visualize this information, as opposed to a strip chart.
Here's a good VBOX article on the subject: https://www.vboxmotorsport.co.uk/ind...-gain-lap-time
Basic Site Sponsor
Basic Site Sponsor
Do you use a math channel for this or just analyze the speed graph?
Good stuff. I'll add average GSum to my list.
gSum average is less valuable to me without very tightly (and repeatable) defined sectors. Plus, a direction change screws that up.
Bring the braking back, hold the brake a little longer, then you'll find less of that happening (giving back leaving what you gain going in).
Rennlist Hoonigan
I've only had trouble at one track and it was specific to that area.
Rennlist Hoonigan
I use the speed graph and one of the very few times I use time on the horizontal axis against the speed measure. Then, do a delta spread between two points of the threshold speed. You will find that a higher vMin often works against the distance or time covered because you can't go back to power as much or as soon.
Basic Site Sponsor
Basic Site Sponsor
Don't we have turkey to eat, or something?
motec i2 pro and I have g meter
Great point on the elevation Matt. I know the camber fairly well and have added the height channel to the sector to at least keep it in mind. I was surprised that mentally I didn't have the elevation down as well as I thought I did.
ProCoach, when you say bring the braking back do you mean brake earlier or later? Also, what are you using for the color map of GSum?
And that article was awesome. Another example of physics not behaving the way we expect.
Basic Site Sponsor
Basic Site Sponsor
Even if you are not as efficient braking, preferably you move the whole braking zone back a little, you just pick up throttle more, sooner going out. Then, the time slip variance isn't so see-saw like in the corner.
I use colored channel GPS map all the time, for nearly every significant measure. Make the channel first, then select the GPS map radio button, then select the multi color radio button that appears above the map all the way on the right. A dialog box will open, select the channel and apply. There are some crucial settings and ranges, I'll post a link from Roger's video, when I find it. VERY useful...
