AIM MXG/MXS new user notes
#76
Good advice so far. The sensor is good to 0C as per http://www.aim-sportline.com/downloa...PT_103_eng.pdf
When I have seen sensors do that before, it's always been a bad connection somewhere. I would check the connections at the harness to patch cable and the patch cable to the sensor. Any contact cleaner would probably help.
Is it pretty common for the binder connectors used on these devices to experience contact issues?
#77
Basic Site Sponsor
Basic Site Sponsor
Received 2,836 Likes
I thought so too, hence my disbelief when i was seeing readings of -95 degrees C in my garage. It's cold here, but not that cold! I figured that the AIM oil temp sensor should at least be reading around 12 deg C, which is what my standalone ECU was reporting the engine coolant as the car sat cold in the garage.
#78
Yes, I really should have done that check to see what effect it had.. :/
I went back to the car in the garage after driving it a few hours ago to check and see if the temp reading is displaying, and it still is.... at 22 degrees C.
I suspect that once cold the readings will be off again. I will confirm that later tonight when I check again.
I suspect that what is happening here is that the cold might be causing a loss of contact in the connection to the sensor that hangs underneath the sump of the car. As the oil heats up in the sump, it may be heating up the entire connection, causing a more positive connection. Just positing here....
That Stabilant seems like it might be the ticket, but it sure is expensive for what looks like a tiny bottle of fluid!
#79
Basic Site Sponsor
Basic Site Sponsor
Yes, but it's the DADDY! It works...
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#80
Rennlist Hoonigan
which cost no drachmas
Not really. It happens everyone once in a while, but I wouldn't say common. Most of the ones I've seen problems with have had some other issue, like wire routing pulling the connector apart, constant water exposure, etc. I think once you find the problem it will be solved for good.
#82
Ok, unfortunately the Stabilant wasn't the solution to the problem, but that is not to say that it didn't do something...
After adding Stabilant, and I think it might have actually have done something to the connection between the sensor and the extension from the dash, because after using it, I now see a string of dashes for oil temp regardless of whether the oil temp sensor is connected or disconnected. Before Stabilant, I was seeing -95 degrees C.
When I connect the sensor, the dash starts displaying temp as -95 deg C, then starts creeping to -99 deg C, and then dashes across the box. This was not something I saw before the Stabilant.
I'm suspecting that the oil temp sensor is pooched, which is odd, given that the thing has not been on the car for 3 months yet. Suffice to say, I'm not very impressed.
#83
The odd thing about all of this is that it seems to work only intermittently while I drive. At random times it will read -95 deg, at which time I get a "cold oil" warning, and then other times it swings the complete opposite direction, giving me my oil overtemp warning. I've had to disable the alarms relating to oil temp in RS3 in order to avoid getting distracted by the constant range of warnings while driving.
#84
Rennlist Hoonigan
Have you tried disconnecting the main harness from the patch cable? If so, did it behave the same? Do you have any other sensors you can put on that channel, connected to the patch cable to make sure the wiring is ok up to the sensor?
#85
I suppose I can try connecting my oil pressure sensor to that same channel to see what happens.
Edit - I spoke too soon - No, sadly I don't have any other sensors I can connect to that same patch cable to make sure the wiring is ok. I have most of the sensors on my car going to the standalone. The only other sensor going to the dash would be the fuel level and oil pressure, but switching either of those over would require some major surgery on the car, as the sensors and associated wires are hidden quite deep in the engine bay
#86
Slight update...
I happened to be doing some tweaking on my standalone ECU last night when I noticed the same oil temp reading on its live display of -50 Degrees C as was displayed on the dash. Thought this was very odd, given that my oil temp sensor is connected only to the dash, and not the standalone. There was no way the ECU itself could have known what the oil temp reading was. I quickly concluded that the value I was seeing on the dash had to be a default value sent from the standalone as part of its data stream. The question though, is why the dash was now displaying oil temp from the data stream, when I had always set it up to display oil temp directly from the oil temp sensor connected to the dash.
Looked in the RS3 software, and noticed that oil temperature is one of the readings that the ECU was streaming to the dash. With that said though, I did not set the dash to display this info, but instead set it up to display what it was receiving directly from the sender connected to one of the dash inputs.
Once I shut off the oil temp data part of the stream from the standalone, the dash now started displaying the correct oil temp for a few seconds after the reboot, only to start displaying negative versions of what should be the correct oil temp. So instead of an oil temp of 14 degrees C, which matches what my coolant temp is as the car sits in the garage, it displays ~ -14 degrees C. Whenever I reboot the system, it displays 14 degrees C for about 3 or 4 seconds, then quickly starts going to negative 14 C.
I tried the different calibrations for sensors, and ended up with even higher negative values, depending on which calibration was used.
The plot thickens!
The plot thickens!
#87
Rennlist Hoonigan
That is odd. I'm assuming you have an AiM PT-100 sensor? I've never had one do that. Just to make sure we're not running into some unit problems, do you have RS2, your logger, and RS3 all set to SI units?
#88
Yes, the PT-100 sensor.
Prior to this, whenever I would change the sensor calibration, there was no difference in what the dash would display, but I know why that's the case now, even though I never set up the dash to display "oil temp" from the standalone.
When this issue first cropped up, I noticed while driving that the readings would fluctuate, changing from what I was used to seeing to a negative 50, then back and forth. As if the dash was trying to decide which oil temp to display.
Checking on the last question right now....
In the settings of RS3, the temps are set to display in degrees C, as I prefer.
RS2 is set to display in km/h, degrees C and PSI. MXG is set up to display oil temp in Degrees C also.
#89
Spoke to Robbie at Aim's office in California, and he thinks it is either an open circuit or a major software bug. Any time there is a negative number for temperature, he says it is due to an open in the circuit.
He could not explain how it was that the dash would switch between data within a datastream and data from a sensor hooked up to the dash, as the software did not have that functionality at the moment.
His suggestions were to switch channels to one powered by a different voltage generator (channels 1 and 2 share the same voltage generator, and channels 3 and 4 share the same generator).
Next suggestion was to install a new oil temp sensor and patch cable.
And failing all of that, send everything in to them to look at and debug.
#90
Basic Site Sponsor
Basic Site Sponsor
My money is on an open circuit...
I've had all kinds of unentered config changes with software/firmware updates... Not an issue, just need to go through it all each time.
Robbie is good people.
