How to remove clear bra video tutorial
Old 08-22-2016, 11:22 PM
Detailed Designs
Detailed Designs's Avatar
Default How to remove clear bra video tutorial
Do you dare to take on clear bra removal? Let us help. Check out our tutorial for our clear bra removal process.
Old 08-24-2016, 02:00 PM
Joemat
Joemat's Avatar
Good video. Thanks for sharing.
Would a heat gun work similarly well?
Old 08-24-2016, 02:45 PM
Detailed Designs
In my opinion, using a heat gun creates more problems with adhesive. But it can be used, yes.
Old 08-24-2016, 03:16 PM
996SPECticle
996SPECticle's Avatar
What tips or differences might there be on car that has had the wrap for several years?
Is there a upper limit on time it should go then it should/must be removed?
Old 08-24-2016, 03:22 PM
Detailed Designs
Excellent question.
The best advice I can give is to look at the film and determine if it has a dried out or has a distressed look. If it does, it may become a bear to remove. In it's simplest form, clear bra is high tech plastic. Just like other plastics, it can become brittle. When this happens, your labor investment in removing becomes higher.
The good news is that even if the clear bra looks ratty it will still do a pretty amazing job protecting the paint until it is removed.
I've removed some horrible looking film that came off in tiny pieces and the paint was *perfect* when we had everything off.
Quick Reply: How to remove clear bra video tutorial
