I made a beginner's mistake
I have been detailing for more than ten years and I recently purchased a 2015 991 GTS. This is my first time with ventilated seats and I wanted to clean and protect the leather seats. I usually use 1 Einzet Lederpflege' Leather Care and top it off with Leather Master Protection Cream. After pouring a liberal amount on the microfiber applicator I noticed that it was too much and a lot went into the inside of the seat. I have been trying to clean it with a soft brush getting the brittles inside the wholes but I have not able to clean it. I also tried inserting a needle on each hole in order to pick up the residue but did not work either. Any thoughts?
Something similar to this:
Spritz some Leathermaster Pristine Clean on them and be VERY gentle as you clean. The edges of the perforations can fray otherwise.
Something similar to this: Amazon.com : Foam Tipped Applicators Poly Shaft 50/pkg : Foam Swabs : Beauty
Just make sure you don't force it. If you used 1z, I imagine that's what's in there. Once, one of my guys put some on too thick and got it in some stitching. Used the same method along with a horse hair brush and it cleaned right up.
You may have to shop for multiple sizes. As cheap as they are, there's no excuse to not have many different sizes available anyways.
Times gone by so the product in the holes may have solidified somewhat.
You need to soften the product in the holes. Try simple applications like hot / warm water with a little soap on a microfiber towel held against the area.It may require a few applications then re-treat the leather surface.
I only use Leatherique to clean my perforated seats it works wonderfully. leatheriquecanada.com
Received 5,388 Likes
Location: London,UK / Florida US State- Dazed & Confused
Perforated or light coloured finished leather - use a foam cleaner (Leather Master™ Foam Cleaner) that contains a surfactant that will lift dirt and soil, allow react time to do its work and then use a soft brush to agitate and loosen the dirt (Swissvax Leather Brush) especially on light coloured leathers; this enables the cleaning of the micro pores and creases and lifts the dirt out and reveal any further work that needs doing (dye transfer, stains, etc.) it should be given dwell time and then gentle agitation with a medium stiff bristled brush to get the product into the materials surface.
The low moisture content of foam can then be easily rinsed and the surface dried. Remove excess product and debris with a clean, damp 100% cotton fibre (do not use microfiber) towel. If the foam is allowed to dry the soil will be re-deposited to the surface (this application method is the correct methodology for all spray type leather cleaners)
