Detail Spray the Wheels?
When detail spraying your car, do you also detail spray the wheels or is brake dust too abraisive for detail spray alone and muset be washed off only? Thanks.
I have been using Quick Detailer or Spray Wax for the past four years on my Spyder and the wheels look great. In fact I have been using QD's on wheels for nearly a decade now with no issues.
You can use quick detailer without washing the wheels. Use a decent microfiber and dedicate a group of microfibers for wheel cleaning only. Using spray wax helps keep the surface slick and makes future clean up easier. Griots is one of my favorites for spray wax, Meguiars NXT Tech is also good.
One of these days I'll take a shot of my wheels after a drive in the country when they are caked with brake dust and bugs. Grasshoppers are especially bad as they stick like glue to the barrels and spokes.
Here's an example of what my wheels look like after a 50 mile drive.
Thanks. I used Griot's spray wax on light brake dust. Turned out great!
I'm surprised by the chips on the wheels with just over 5,000 miles.
Your wheels look very nice. I'll keep up the routine.
The "wax" in QD is going to boil off in no time due to temperature of the wheels.
When wheels are not too bad, I use Poorboy's Spray & Wipe (it has no wax) to clean them, without a hose and bucket - just sitting on my bum in the garage.
However, the key is to seal the wheels. CarPro HydrO2 is incredibly easy to use on wheels and seals them for a good month. It only takes seconds to apply. Colinite 845 or 476 also work well on wheels, but it's a lot more work that Hydro2.
If you keep your wheels sealed, washing or wiping clean is a snap.
Can anyone compare Wheel Wax to the other sealers above? I pull my wheels a couple times a year and do the barrels and face with it. It's easy to clean with car wash and water and the Wheel Wax keeps the brake dust from sticking.
1. Wheel Wax: This is good, as long as you keep applying it every so often. That can become a pain when removing the wheels often to apply for to barrels
2. Sealant: Again, similar to wax, except that it could last a little longer
3. Hydro2: As mentioned. This has got to be one of the easiest ways to protect your wheels, heck, even the whole vehicle. Wash your wheels, while they are wet, spray on and pressure rinse off. Its seriously like magic!
4. Specific coating: Initial cost for this is higher, but because these coatings are made for high temp applications, they will last longer. Modesta mades BC-06, it is rated at well over 1,000 degrees. It is a pro only application, and it is a spray application. It is best to take the wheels off, prep them and then have this installed and infrared cured to the wheels. CQuartz makes Dlux and you can also have them coated with CQuartz Finest.
These are the two options I am familiar with, I am sure there are others. Application cost can go from $350-$650 for wheels off.
It all depends on what you want to do. Something is better than nothing at all in my opinion.
HUMP
I have also tried sealant waxes and while they are easier to use as compared to the wheel wax the effort isn't worth it.
Based upon what others are stating, it sounds like a coating is the best approach, I need to give it a shot to see how it compares.
My non sugar coated opinion based upon my own experience, YMMV.
