best way to remove tire rubber from paint?
Old 08-26-2013, 12:00 PM
PasPar2
PasPar2's Avatar
Default best way to remove tire rubber from paint?
Have some spots of this stuff post HPDE - what the best way to remove it?
WD40? Googone? thanks
Old 08-26-2013, 04:35 PM
Cowhorn
Cowhorn's Avatar
I have had a lot of good luck with Bug & Tar remover.
Old 08-27-2013, 06:57 AM
seapar
seapar's Avatar
Mother's r3. Racing rubber remover.
I also have used meguiar's cleaner wax .
Old 08-27-2013, 08:01 AM
TOGWT
TOGWT's Avatar
Location: London,UK / Florida US State- Dazed & Confused
Default Removing dried -on rubber
Use a safe solvent to remove burned on rubber; that does not contain any harmful components (heptanes or xylene or hydrocarbon aliphatic solvents; Autoglym Intensive Tar Remover, Stoner™ Tarminator, or Wurth Spray Solvent that simply emulsifies and dissolves the rubber, then use a plastic razor blade to remove any hard debris.
If this does not remove the rubber try a
3M Eraser wheel – this 4-inch diameter wheel is made from a soft white polymer, which looks and feels like rubber. 3M Stripe and Decal Remover
Old 09-14-2013, 03:51 PM
sjfehr
sjfehr's Avatar
Mr. Clean Magic Erasers (and generic knock-offs) do a great job. They work largely through mechanical action and seem to really do a good job at peeling the rubber off the paint instead of trying to dissolve it off.
e: ha! Turns out Mr. Clean Magic Erasers are literally the same untreated BASF Basotect foam Porsche uses for engine acoustic/thermal insulation because it absorbs high and medium frequency sounds and blocks heat while letting the engine growl come through. Talk about multipurpose material. Wonder if I can buy it cheaper as bulk insulation? I go through 1-2 bricks cleaning my wheels every time I wash my car
Old 09-25-2013, 03:29 PM
Autogeek.net
Former Vendor
Autogeek.net's Avatar
I second this.
Quick Reply: best way to remove tire rubber from paint?
