Leather Touch Up, Great Solution
#31
Sure they are Jerry, take a closer look. All creases are exactly the same between the two. Only real difference is the lighting.
#32
P.S. Here's a "before" shot I took myself:
#33
Bumping this so I can refer to it. Need to do the same to the seats I picked up.
#34
Location: London,UK / Florida US State- Dazed & Confused
Great job on the seat renovation
Leather World Technologies Top Coat is a water-based clear coating for finished (pigmented) leather. This product provides a clear finish designed to give abrasion protection and better durability for finished leather.
#35
Leather or Viynl repair / re-colouring - http://www.magicmender.com/
Also any opinions on the "leather doctor" kit?
http://www.leathercleaningrestoratio...splay.php?f=10
TIA
#37
Looking at the link, I'm a bit torn on what to do. My seats will need a very comprehensive repair as well as several parts of my leather interior. The Leatherique way has you sanding. The magic mender does not.
TIA
TIA
The product I used was based upon a recommendation from an expert that performs custom leather work.
I had seen several Leatherique repairs and although it looks significantly better the one pet peeve I had was that the finish was too glossy.
Let us know what you end up doing and post some before/after pictures!
#38
I have used both Leatherique and Magic Mender repair/dye products. I would recommend Leatherique's Leather Rejuvinator and Pristine Clean products, but for touchup, I prefer Magic Mender products.
Besides the complete selection of Porsche factory color dyes (see below chart from Magic Mender site), Magic Mender also sells a leather grain spray and clear coat. So, if you do some sanding, the grain spray will give a orange peel look instead of the commonly seen smooth and grainless touchup. If your seats have previous touchup work, the clear coats Magic Mender sells can be used to hide any gloss patterns.
Access to an airbrush and airbrush compressor is key to professional results. The airbrush ultra fine spray feature allows easy blending the new dye with the old.
#39
Unfortunately I did not do my homework correctly and based on this thread I completely re did my seats with Magic Mender in March. Painstaking procedure, followed all direction to a T. I was also swayed by the fact that they were the only provider of my unusual color ( Silk Grey).
At first the seats looked great. Felt a bit plasticky to be honest, but they looks new.
As of late with the summer heat, my car has to stay in the sun when i'm at work. The seats started to feel very tacky, like i was seating on the back of a scotch tape! the color literally has started to come off and yesterday I tried to clean them without chemicals only for paint to come off on my rag. Not to mention the traces of paint in my clothing for the past little while.
So they are GARBAGE. unfortunately when I googled "magic mender problems" i came upon several threads on the BMW forums describing the exact same issues that I have.
So, now back to square zero for me, any solutions would be appreciated.
#40
Great job on the leather renovation Marine Blue.
As with most things relevant to detailing the most important step is proper surface preparation
“Leather Restoration” - http://www.autopia.org/forum/autopia...ml#post1479003
#41
I followed the instructions of the actual product to a T, I even took most of the color out and had the seats in a controlled environment, out of the car for weeks to do this properly. I even left the seats out of the car for another week before installing to ensure the product has cured perfectly.
The fact remains that the product "magic mender" you recommended is garbage.
Probably you have a vested interest in this product but you should disclose that.
otherwise I cant explain that an "expert" such as you present yourself to be would recommend such garbage.
#42
Hi,
I know this an old thread, but I'm curious about the difference between "silk grey" and "linen grey". Can anyone provide photos detailing the difference? I was able to decipher 7VT as silk grey carpet, but the other codes, QM and TL, I can not find a reference to these options.
My car: 1990 964c2.
Thanks,
HB
My car: 1990 964c2.
Thanks,
HB
Last edited by JV44HeinzBar; 05-13-2014 at 12:32 PM. Reason: forgot to add the year
#43
I just touched up the seats in my low mileage 1990 964 with Leather Magic. I could not believe that they had my somewhat rare Can Can Red! Perfect results. I wish I had thought to do before and after pics. Of course I have no idea how to post pics anyway, but I am extremely pleased with the results? The product was delivered very quickly, but with no directions what so ever. I followed the guidance of a fellow RennList member on this post and the results were great. I bought the small bottle, and I think it's enough to do the whole car. A little goes a long way. My seats are in very good shape, but had the always present left hip cracks in the coloring. I used a clean rag and feathered out to the crack free areas. I'll post durability later, but I have enough extra product to do this treatment many more times if needed. Two thumbs up to LEATHER MAGIC.
#44
Danny thank you for posting your follow up on Magic Mender. Your observations are similar to what I have seen from a few different products. My first 928 had been redyed by a previous owner and I observed the same sticky surface and product removal when I cleaned the seats. As noted in my original post, the product I used worked extremely well for touch up of small areas and it blended perfectly. I would be interested in others observations for repairing a larger area and how the product has held up.
#45
Thanks for the great input here, really appreciate it. I was led to this thread when I posted a new one seeking for views and suggestions on how best to deal with an interior and seats like this:
As you could see there are visible and extensive areas of scuffs and marks, but I cannot see any substantial tear through the leather. I really like this car and wonder if you think, according to your experience with Leathers Magic or other products, that these could still be remedied or repaired?
I used to be a fan of black interior not just that it's classic that can withstand time but also that it's the safest choice. As for chestnut interior like this one, I am not sure if it looks okay at first but I was pleasantly surprised after I viewed this car.
Would appreciate your input as to whether these are fixable coz it's one of the key issues to me. Many thanks in advance. Good day all.
