V8 Oil Change w/pictures
Old 05-14-2012, 07:37 PM
Slow Guy
Slow Guy's Avatar
Originally Posted by XR4Tim
The PIWIS is more accurate than the instrument cluster. It shows the oil level value in millimeters, and there is a chart that shows how many mm is considered "full" depending on what type of oil level sensor, and what software your vehicle is running.
I wouldn't be too worried about reading it with the instrument cluster. At worst it may be ½ quart off. Great write-up!
Interesting. Thanks for the info. Wonder why they don't put that kind of accuracy in the inst. cluster since the (pick up) sensor is most likely the same?
Slow Guy is offline
Old 05-14-2012, 08:48 PM
Mike in CA
Mike in CA's Avatar
Originally Posted by w00tPORSCHE
You are god sent Mike.
Too kind, Amar....
Originally Posted by Andy E.
Nice write-up Mike! Are those salt stains on the sub-frame?
Thanks Andy. I've never been anywhere with salted roads. We have hard water from our well so it could be residue from that but I don't typically hose down the engine or under the car. Probably just dirty splash from puddles; there are openings where water can get in from the sides. Should have cleaned it while I was under there but too lazy.....
Mike in CA is offline
Old 05-14-2012, 09:37 PM
Slow Guy
Slow Guy's Avatar
P!g frolicking in puddles, nothing wrong with that!
Slow Guy is offline
Old 05-15-2012, 10:18 AM
911SLOW
Admin
911SLOW's Avatar
Originally Posted by 993BillW
Just because I feel like being an *** today you could only manually check it with a dipstick or counting the amount of oil you put back in during the change. Using a PIWIS tester is still doing it electronically. I don't imagine they have a 2nd sensor reserved for the PIWIS tester so they must consider the electronics in the gauge setup to be inaccurate. That's weird.
Agreed but I used Porsche's phraseology.
911SLOW is offline
Old 05-15-2012, 10:35 AM
Slow Guy
Slow Guy's Avatar
Wouldn't it be so much easier for Porsche (and other mfgrs. too) to just go back to the simple (and reliable) dipstick? (KISS principle anyone?) I wonder how much time and $$$ Porsche has expended on oil level related issues?
I went through much the same thing with my wife's first BMW (a '07 328 H/T Conv). I did the first oil change myself and intentionally left it almost 1 qt. shy when I refilled it. It was almost a week before the on-board system registered the oil as being 3/4 qt. low. I never trusted that thing after that. It's one thing to be inaccurate on a dry sump car w/ and 11 qt. capacity, quite another on a wet sump w/ 6.5 qts. (IMHO).
Slow Guy is offline
Old 05-15-2012, 10:43 AM
911SLOW
Admin
911SLOW's Avatar
How dare you.. What if a drop of oil hits my Chanel?
911SLOW is offline
Old 05-15-2012, 11:07 AM
Slow Guy
Slow Guy's Avatar
My apologies Sir! I failed to consider that. A fresh drop of oil or 2 would greatly enhance my ensemble though.
Slow Guy is offline
Old 05-15-2012, 12:20 PM
XR4Tim
XR4Tim's Avatar
I'm sure they don't want owners keeping an eye on exactly how much oil their car is consuming, especially if it's minimal.
XR4Tim is offline
Old 05-16-2012, 12:12 PM
Slow Guy
Slow Guy's Avatar
I think we probably have a certain member of this very forum, who drives a turbo, to thank for this.....
Why can't they just be thankful that Porsche decided to build the P!g and leave it at that??
Slow Guy is offline
Old 05-16-2012, 02:00 PM
azzurri
azzurri's Avatar
Thanks so much for posting this. Really appreciate
azzurri is offline
Old 05-16-2012, 06:41 PM
KevinGross
KevinGross's Avatar
Echoing others, nice write-up.
Kevin
KevinGross is offline
Old 05-16-2012, 08:12 PM
Mike in CA
Mike in CA's Avatar
Kevin
You're welcome and thanks.
Old 05-18-2012, 11:13 PM
YRUNVS
YRUNVS's Avatar
Default DIY oil change
Great post and pix! Do you know if anyone has done this for the 2011-12 V6?
YRUNVS is offline
Old 05-19-2012, 12:47 AM
Mike in CA
Mike in CA's Avatar
Thanks. Not that I've seen....
Old 06-25-2012, 09:07 PM
r6bruin
r6bruin's Avatar
Nice write-up, Mike! The DIY photos with 997 at the back makes it truly one of a kind
r6bruin is offline
Quick Reply: V8 Oil Change w/pictures
