O.Z. Alleggerita HLT for 2003 Boxster S?
Trying to figure out if the Alleggerita HLT wheel combo of 18x8.5 53mm offset and 18x10 40mm offset will fit correctly on a 2003 Boxster S.
Anyone ran this combo or know if they will work?
http://www.willtheyfit.com/index.php...8-5&offset2=53
http://www.willtheyfit.com/index.php...=10&offset2=40
Thanks!
Thanks!
1" lower coil springs all the way around. The rear poke to the fender of 24.7mm more than stock tires and wheels makes me worry.
no, ..I do !
I can even add that these (great) wheels DO clear my front brakes (big brake Brembo kit, with 6 pistons calipers).
These do also clear the PSS9, ..but I should admitt, the rear rims are ..very-very close to the PSS9 tubes !!
See the story here :
https://rennlist.com/forums/boxster-...l#post12557119
no, ..I do !
Thanks!
