Boxster & Boxster S (986) Forum 1996-2004
smooth out 2nd gear ?
Old 11-01-2016, 10:05 AM
mfm22
8th Gear
mfm22's Avatar
Question smooth out 2nd gear ?
986 - '02 base - 53k shifting into 2nd can feel a bit notchy [is that a word ] sticky
sometimes smoother than others , i'm trying to get used to car and this is something I found in most of manual trans - it may be me
It seems better when keeping revs down , I tend to pull out of 1st and wiggle back into 2nd trying to find smooth drop . maybe better going straight back
all other gears are smooth as can be
Old 11-01-2016, 11:52 AM
GTgears
GTgears's Avatar
What rpms do you shift at? You are actually probably shifting too low.
Old 11-01-2016, 05:22 PM
mfm22
8th Gear
mfm22's Avatar
maybe , I'll pay more attention ... probably around 2000- 2500 any suggestions ?
Old 11-01-2016, 05:36 PM
GTgears
GTgears's Avatar
3500-4000... Your car makes zero power down low. The engine isn't designed to run down there. There is zero reason to shift down there.
Quick Reply: smooth out 2nd gear ?
