Boxster & Boxster S (986) Forum 1996-2004
Oil Level Sending Unit, 2.7 Boxer, 2002
Old 08-28-2016, 05:35 PM
Jakester1
8th Gear
Jakester1's Avatar
Default Oil Level Sending Unit, 2.7 Boxer, 2002
Where is the oil level sending unit located and how do you change it?
Just bought this 2002 Boxer and learning the mechanics.
Please Help Thanks,
Jake
Old 08-28-2016, 05:58 PM
Macster
Macster's Avatar
Please Help Thanks,
Jake
The unit fits into the engine from up top under the intake manifold. I can't remember where exactly as it has been years since I have had viewed the engine and none of references show its location either.
Should be (should be) obvious. Has to have a wiring harness connection so look for that. About the only other things in that area are the knock sensors and they are off to the sides on the heads.
Not sure if you can remove this with the intake manifold in place or not. It is kind of long, nearly a foot I think. (I bought an old one and cut it apart to learn how it was put together and how it worked.)
Old 08-28-2016, 06:39 PM
Jakester1
8th Gear
Jakester1's Avatar
Thanks, I can see it under the intake, I've been looking all day on the car and the internet
Thanks,
Jake
Old 08-28-2016, 11:09 PM
Macster
Macster's Avatar
Thanks,
Jake
You are welcome.
Be careful when you remove it. That hole leads right down into the bowels of the engine. Drop something and you might have to drop the engine and split the cases.
Why are you replacing the oil level sensor?
Old 08-30-2016, 11:50 AM
Jakester1
8th Gear
Jakester1's Avatar
I replaced the sending unit because on the dash the oil level indicator well just keep blinking an never show the oil level. I'm sorry to say changing the sending unit did not fix the problem. Hine site, I should have asked the question here before changing the unit.
Thanks, Jake
Old 08-31-2016, 10:44 AM
emore93
emore93's Avatar
It can be fixed. I had a similar problem with a 996 gauge.
I had Qmulus Tech do the repair.
Old 08-31-2016, 01:26 PM
Jakester1
8th Gear
Jakester1's Avatar
Does anyone know how to trouble shoot the system, what to check, I would like to learn as much as I can about my car and how to fix it. I've brought a Bentley Publishers Service Manual and it not much help. Any help would be appreciated.
Thanks,
Jake
Old 08-31-2016, 01:32 PM
Qmulus
Qmulus's Avatar
Unfortunately that is a fairly common problem in my experience. The problem is actually in the instrument cluster and often results from a jump start or connecting a jump box or another batter with the polarity reversed.
PM me if you are interested in getting it repaired.
Steve
Old 09-01-2016, 01:18 PM
Jakester1
8th Gear
Jakester1's Avatar
Steve, what does it take to fix this, my e-mail is
jake.jake@comcast.net
Please let me know
Jake
Old 04-21-2022, 09:43 AM
Obvals4ik
2nd Gear
Obvals4ik's Avatar
Steve
Hi! I have the same issue
Have you solved it, and can you help me with that?
Old 10-15-2023, 12:48 PM
Pashu
Pashu's Avatar
Steve
Hi Steve,
can you please share what it takes to fix the problem? I have the exact same issue with my 2001 Boxster S.
Quick Reply: Oil Level Sending Unit, 2.7 Boxer, 2002
