Boxster 986 1998 missfire on cylinder 3
hello ty for the quick reply ...
i had a friend come ... he is a very good electician .. he sed to me that : there is no electical problem .. i have piwis clone ... the car is little beter wen the engine is warm up ( but u canot drive the car ... )
i trust him .. we tested injecotrs , end the spark from the coil ... its very good ..
i worck in a service ... il buy cam tools tomorow morning ... end take the engien down ... clean it , change solenoid bank 1-3 ,4-6 verify the valves ... mby the one from cyl 3 is broken end its remains opened or closed ... ty for your reply ... il take pictures end whrie about the procedure ...
sory for my bad english ... hope u can understand it
Well, it is your call to take the engine down. These engines are not that straightforward to work on. AFAIK Porsche publishes no info on engine disassembly/assembly. In the past I didn't blink in disassembling a couple of engines but I'd be very reluctant to tackle my Boxster engine.
However, some owners have managed to get the engine apart and more importantly back together again and a few have published what they did and how.
If you have a PIWIS clone you can check cam timing readings and possibly even trigger cam timing changes if you suspect a VarioCam solenoid/actuator is the problem.
The sound of the engine didn't sound like my Boxster's engine when a VarioCam solenoida/actuator proved to be bad, but maybe there are different levels of failure. After I briefly shut off the engine and then restarted the engine the symptoms were gone and the engine ran just fine. Good enough I drove it 30 miles home with no drama. However I didn't push my luck but got the car in pronto.
The tech told me the engine can misfire if the problem, the failure is bad enough. Because the timing is not right the O2 sensor readings aren't what the DME wants to see and it will adjust fueling in an attempt to get the desired O2 sensor readings. It can go too far and fueling becomes so bad the engine can misfire. Using an OBD2 code reader/data viewer I observed the short term fuel trims swinging wildly about but I do not remember if the DME would end up adding too much fuel which would end so to speak in rich misfires or too little fuel which would end with just misfires (due to a too lean condition).
Anyhow, best of luck with whatever you do and I hope whatever you do addresses the problem.
Intake valve leak is rare. Why is it leaking? Bad seat? "Stuck" valve? Does the valve edge have a bad spot in it? On an exhaust valve the bad spot would have soon been burned/melted to a small V notch looking almost like one took a small cutting torch to the edge of the valve. Not sure this happens to the intake.
