Help! Door will not open
Locked door with key. Then unlocked door with key. Pulled outside door handle, door would not open. Tried unlocking with fob (remote), pulled outside handle, no difference - would not open. Tried opening from inside, would not open.
Removed inside door panel, pulled both handles - separately, and could confirm that mechanism connected to handles was moving.
When turning key, or using fob, can hear lock and unlock action. Still door will not open.
Took power away by disconnecting the battery. Tried again with key, no difference.
Is lock not unlocking, or is the latch just not releasing? How can I get the door open? Passenger door works fine.
Thanks,
Joe
Thanks,
Joe
Same door problem
Thanks,
Joe
Thanks,
Joe
I assume that your door latch should look like the one pictured below. the lock position should be visible in the circled are, which sits above the connection for the inside door handle cable. the picture below shows the latch in the unlocked position. the foot of the internal handle actuator is designed to push the lock to the unlocked position on the first pull then on the second pull the door should be unlocked and therefore open. if there is something restricting or causing the lock to spring back then any subsequent handle pull with still be trying to unlock the system instead of opening the door. Can you check to verify that the unlock position is achieved via the.key, remote or first pull of the internal handle. if it doesn't fully unlock by the previous methods you may need to reach into the door and push it to or hold it in the unlocked. then try one of the release handles again.
BondJ (07-22-2022)
Pay a professional locksmith to open the door. Then replace the lock assembly. That the culprit in most all of these cases!
Follow this procedure...
https://rennlist.com/forums/996-foru...-detailed.html
