Boxster & Boxster S (986) Forum 1996-2004
Brake Lights working backward
Old 05-26-2015, 08:31 AM
Bruce Mills
2nd Gear
Bruce Mills's Avatar
Default Brake Lights working backward
I have a 1997 Boxster, the brake lights are on when my foot isn't on the break and then go out when I put my foot on break pedal.
So basically the reverse to what should happen.
Any suggestions?
Old 05-26-2015, 08:44 AM
extanker
extanker's Avatar
might be as simple as a brake light switch or [rare] a weird back feed issue
Old 05-26-2015, 08:50 AM
Bruce Mills
2nd Gear
I thought switch, but then thought maybe relay?
Is there a Relay on brake lights?
Old 05-26-2015, 01:15 PM
Macster
Macster's Avatar
I believe you hit upon the cause I too believe it is a back feed issue. Corrosion some place is letting current flow the wrong way. Not lots of current just enough to light the bulbs.
But where this corrosion is I have no idea.
Old 05-26-2015, 09:15 PM
Qmulus
Qmulus's Avatar
Check the wiring at the pedal switch. That is about the only place that you could have an issue that would cause that symptom.
There is a normally closed terminal (labelled 4) with two black/red wires, a normally open terminal (2) with a black/orange wire and the connection for power (1) with a solid black wire. It is possible that the black/red and black/orange wires were swapped at one time, or perhaps the switch is bad.
Old 05-30-2015, 05:23 PM
whalebird
whalebird's Avatar
Sometimes people will force a bulb into a socket (double filament) where the side lugs are offset....backwards. The double contacts at the bottom of the bulb crosses the contacts in the socket creating a feedback. Can't remember if boxsters use dual filament bulbs, but the rear fog light might be a place to look. Check all bulbs for proper fit and location.
Quick Reply: Brake Lights working backward
