Horn Problem (not the standard one)
Well, I had the standard worn horn issue but I fixed that. Shortly after, my horn became intermittent, and then stopped working entirely. The fuse is intact. While driving along, I occasionally hear a sparking or crackling noise in the steering wheel, which goes away as soon as I press the horn. My preferred Porsche mech said there were some brushes behind the wheel that get worn out and need to be replaced, but he moved away and I don't trust the new one so I'm looking at you. Any ideas would be appreciated.
Thanks!
Thanks!
Thanks!
Thanks!
Sounds like the only real problem you are faced with is finding another Porsche mechanic you can entrust the job to.
If the diagnosis is correct -- and I have no reason to doubt it -- the sparking/crackling noises is electricity arcing and this is just going to erode/damage the contacts even further, necessitating even more work to put right. So I would not delay in getting this addressed.
If your preferred Porsche mechanic made the diagnosis and you trusted him then have the brushes done, or replaced or whatever is called for.
most likely its the small rubber ring type "springs" in the horn assembly.
there are two recessed hex head bolts holding the air bag/horn cover on the steering wheel from
the back side. They can be a pain to crack loose.
Mike
Mike
Thanks for letting me know. I couldn't find them on any of the exploded assembly in Pelican parts. would anyone be able to link me to them? Are they easily replaceable, or is it a new assembly?
Thanks in advance, I'm not usually this hopeless but it's the first time I've seen this issue posted about on the interwebs.
