Boxster & Boxster S (986) Forum 1996-2004
Sticky Knobs...
Old 10-22-2014, 10:34 PM
nc_growler
nc_growler's Avatar
Default Sticky *****...
Hi.
First post to the 986 forum. Long time poster in the 928 forum. I did several searches for this issue, but wasn't able to pick the right words or phrases to find a thread on this subject.
Picked up a very nice Seal Gray Metallic 2006 Boxster S last weekend.
The one issue that I have with the car is that the Temperature and Fan ***** on the climate control are super sticky. I believe they may originally been coated with some sort of rubberized paint to help with tactile feedback?
Now it's like they have sort of dissolved and white is showing through the surface?
I'm assuming many of you must have encountered something like this?
Do you know if these ***** can be resurfaced or even replaced? Is there something aftermarket that holds up better?
Looking for ideas. Thanks in advance!
(Oh, I guess I'll need to update my signature soon!)
Old 10-23-2014, 01:22 PM
tone40
tone40's Avatar
Default This is not the exact same issue....
But, similar. I just re-coated the radio ***** on my Boxster. If you can remove the *****, then read my post on the main forum of Pedrosboard.com
The topic is labeled:
Old Topic, now a minor inconvenience.
The re-coating has worked perfect so far.
Old 10-24-2014, 06:55 PM
nc_growler
nc_growler's Avatar
Thanks for the pointer to your other post. I'll check out what you did for the *****.
It wasn't very clear to me how to remove these ***** without special tools as it looks like a portion of the control console needs to be removed. Is there a trick for that? I'm going to start doing some additional reading on that subject.
Old 10-24-2014, 09:53 PM
tone40
tone40's Avatar
Default Post the question for **** removal on Pedros Board....
It is very active and the members are experienced. My Boxster is older that yours. ***** are probably different.
Tony
Old 10-28-2014, 01:34 PM
nc_growler
nc_growler's Avatar
Thanks Tony.
One thing that I noticed that is different here is that my ***** have actual icons on them. I'm assuming I could re-paint them black, but then the "light through" icons would be obscured.
Old 10-28-2014, 01:35 PM
nc_growler
nc_growler's Avatar
Oh, and my apologies in advance for posting in 986 forum. I should have posted in 987.
Old 10-31-2014, 10:49 AM
TomiK
TomiK's Avatar
Try cleaning them with rubbing alcohol (the stuff you buy at a pharmacy) first. That worked for me but mine were only a little sticky (not super sticky, like yours)
Old 10-31-2014, 11:56 AM
extanker
extanker's Avatar
tactile feedback ?
Old 11-01-2014, 06:51 PM
nc_growler
nc_growler's Avatar
Extanker - that has to be why they have this type of coating. They feel somewhat rubberized when you touch them, but mine have moved to sticky and the original "Temp" and picture of a fan have started to dissolve off the *****.
Quick Reply: Sticky Knobs...
