Boxster & Boxster S (986) Forum 1996-2004
View Poll Results: Has your IMS failed
No failure
88
86.27%
Yes my IMS failed
14
13.73%
Voters: 102. You may not vote on this poll
IMS poll
Old 12-25-2015, 04:51 PM
  #76
Tim Lawton
Tim Lawton's Avatar
I have a '99 986. bought it at 80k+/-....
had a water pump and clutch going south on me at 90k.
ims bearing good but replaced it since the clutch was down to the rivets...
the bearing was actually good. but why not change at this point?
tim
Old 12-31-2015, 11:01 PM
  #77
Por356c
Por356c's Avatar
Default IMS Replacement
Hi - 3rd owner of 02 Boxster. The 2nd owner had the LN kit installed at 40k just before I bought it. Nice to have the peice of mind.
Old 02-29-2016, 10:50 AM
  #78
TristanCBR
TristanCBR's Avatar
2001 Boxster S, 92K no known IMS replacement or issues.
Old 02-29-2016, 04:51 PM
  #79
Tim Lawton
Tim Lawton's Avatar
Originally Posted by TristanCBR
2001 Boxster S, 92K no know IMS replacement or issues.
I kind of felt that way too. if I hadn't had to do a clutch job, I may have just gone my merry way...however, I sleep better at night and I make a lot of road trips to places where no one has ever heard of a "porch"...
Old 03-01-2016, 09:29 AM
  #80
TristanCBR
TristanCBR's Avatar
Yeah, if I had to pull the engine or trans for any reason, I'd knock the other stuff out too as "might as wells"
Old 03-06-2016, 11:22 PM
  #81
arrakis
arrakis's Avatar
Replaced IMS as preventative maintenance on my '03 Boxster S at 45,709 miles. As well as rear main seal (was leaking), water pump, clutch, spark plugs and belt.
Old 04-30-2016, 03:56 PM
  #82
mueber
mueber's Avatar
Default Having it done now
Mine's a 2000 Boxster S with 43,000 miles. It hasn't failed. I'm having in done during the upcoming week along with a clutch replacement by a garage I've used for years.
The technician recommends the Porsche factory IMS upgrade kit. He is assured by Porsche I will have no problems with it. Anyone have any thoughts on this?
Old 04-30-2016, 04:24 PM
  #83
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,282 Likes on 899 Posts
No such product exists!! There's never been a factory Porsche IMS retrofit kit. No part number for an IMS bearing exists, only a complete IMS shaft assembly. This is well known fact.
This technician is clearly out of touch, and has no idea about this issue, and the available products to address it.
Al Allen (11-01-2023)
Old 05-01-2016, 03:02 PM
  #84
mueber
mueber's Avatar
Has anyone had their IMS service done by a dealer? If so, what did the do, and what products did they use?
Thanks,
Mark
Old 05-01-2016, 03:15 PM
  #85
Flat6 Innovations
Former Vendor
Thanks,
Mark
Dealers have been using genuine LN Engineering retrofit products since 2008. Back then they'd make the car owner buy the retrofit kit, today lots of dealers stock the parts.
BUT not a single dealer in the world is an IMS Solution Certified Installer.
Old 05-01-2016, 05:30 PM
  #86
paulofto
paulofto's Avatar
Thanks,
Mark
The dealer here has done many. In fact they welcome you to bring them the bearing of your choice or they will supply an LN bearing but they confirmed Porsche does not supply a stand alone bearing, only the entire shaft assembly which will require an engine disassembly to install. Prohibitively expensive and kind of counterintuitive to install the same bearing that they are removing.
Old 05-02-2016, 08:55 AM
  #87
mueber
mueber's Avatar
I just received an email from the local dealer confirming the LN Engineering bearing, and based upon my mechanic's quote, I suspect his parts supplier is providing the shaft assembly. I just called them to cancel the appointment to do the job.
Thanks again, everyone.
Old 05-13-2016, 03:58 PM
  #88
mueber
mueber's Avatar
It's in the shop and being done at a much lesser price. Soon you can add me to the list of those who have not had a failure but have had it done.
Old 09-16-2016, 12:56 PM
  #89
mjberning
Cruisin'
mjberning's Avatar
Default 2002 Porsche 996 with 28000 miles
No IMS failure yet on this 14 year old car
Oil changed 4 times a year regardless of miles driven. I like to drive the vehicle at 3000 RPM and rarely use 6th gear unless Im on an open road
Will get IMS updated when I do the clutch
Still pondering the options
1) IMS solution is too expensive for the parts you get. Many repair shops says that its a waste of money given the low rate of failures and the other options out there that make that low rate of failure even lower.
Id rather get one of the below and also change water pump and solve more engine issues than just IMS. The LNE company makes really good products but is starting to get P996 owners to fetishize the IMS bearing over all other maintenance items. Best to get the most engine protection for the money.
a) LNE Single Row Pro sold on Partsgeek for around $600. The double row should last more than the 75000 mile service interval if its better than OEM and I maintain the vehicle and drive it like I have been.
b) Vertex roller Bearing with oil feed which is supposedly a permanent fix and sells for $450 on Ebay. No known failures reported on the internet and it meets the requirements for how I drive and change my fluids.
Old 09-16-2016, 07:15 PM
  #90
Tim Lawton
Tim Lawton's Avatar
I had my IMS and clutch done at 94000 miles. The bearing was still good. Do I sleep better at night??? YES.....
I also had to do my water pump at some point after that. Actually, I have spent more money on rebuilding the rear suspension than anything else.....
a 14 year old car with only 28000 miles??? Jeebus, do like I do and drive the firkin car every day. It'll last longer....
Tim
Quick Reply: IMS poll
