Boxster & Boxster S (986) Forum 1996-2004
Need radio code
Old 01-18-2012, 12:48 AM
silverboxter
3rd Gear
silverboxter's Avatar
Default Need radio code
I had to replace the battery on my wife's 02 Boxster S. It has the original CDR-220. The serial number is 15007385.
Does anybody know what the code is?
thanks in advance!
-Wil
Old 01-18-2012, 05:39 AM
Gert
Gert's Avatar
Just call your dealer, give them the VIN nr and they should be able to give you the code.
Old 01-18-2012, 12:16 PM
logray
logray's Avatar
Or head over here with your request:
http://www.renntech.org/forums/topic...r-request-here
"Which radios fitted to Porsche can have their unlock code recovered through serial number?
- CR-220/CDR-220 - Becker
- CR-210 - Becker
- Traffic Pro NAV/CD - Becker
Which radios can not have their unlock code recovered through serial number?
- CR1 - Alpine
- CDR-23/24 (or later) - Becker
- PCM (Porsche Communication Management) – Siemens & Becker
How to get your radio serial number?
CR-220/CDR-220:
Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right **** (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
Or, if the radio is out of the car the then the serial number is on the label.
CR-210:
Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of numbered buttons below display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
CDR-23 (or later):
These radios do not have a security code - that is, not that the user enters.
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
Traffic Pro:
Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control **** to select the individual items.
You can move through the following items:
- Model-No.
- Serial-No. <-- this is what we need
- Changer Reset
- GAL
- Radio Software
- Radio Bolo
- Navi Rom
- Navi Flash
- RTC Value
To quit the service menu, press END.
I get a WAIT in the display - what do I do?
You have to wait 1 hour - with the radio on and ignition switch on (or the car running).
Neither of the suggested numbers worked - what do I do now?
My program does not always work. It works maybe 95% of the time but I have no explanation why it doesn't always work.
You can try 2 digits different each time (and sometime that works). So if your code is 1013 - then try codes 2 digits different from that code (i.e. 1011, 1009, 1015, 1017. etc.)
If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers do too.
Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC.
Can I post my VIN to get a code?
We do NOT need your VIN - only your radio serial number.
Where can I post my lost code request?
Please post your request here:
Lost Radio Code - post your request here
Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread. "
from http://www.renntech.org/forums/topic...adio-code-faq/
Old 05-24-2015, 10:32 PM
nejatali
nejatali's Avatar
Help please.
CDR-220
Type 4462
Ser X5026924
Fixed horn lost radio
Old 11-23-2015, 04:03 PM
DrChipRepair
DrChipRepair's Avatar
I am brand new to Reenlist. This is my first post. My 2003 Boxster S Bose CDR23 radio will not turn on and only "flashes" PORSCHE. Dealer says it is shot and I must purchase a new one for $795. How do I know it is really shot? I see many used CDR23 radios for sale. Does a replacement radio, if needed, have to have the same part number as on my radio? Thanks much for any help!!
Old 04-17-2016, 04:26 PM
JDAY996
3rd Gear
JDAY996's Avatar
Lost my books and radio code was in it. I have a Becker CDR220 in a 2002 996. Serial # 15001316 - can anyone help?
Old 04-17-2016, 07:30 PM
Macster
Macster's Avatar
See post #3. Loren at renntech.org can supply your radio's code. I think you have to join renntech first though. I'm a member and submitted a code request to Loren and he responded promptly and that was that. The code worked perfectly. I had to drive the car 30 minutes before I entered the code Loren supplied as I tried a number thinking it was the code and it wasn't.
A dealer should be able to help. You might have to show up in person and there might be a charge. My dealer supplied me with my radio code once at no charge.
Old 04-26-2016, 09:38 PM
tommy583
2nd Gear
tommy583's Avatar
Post your radio code questions on 986forum.com. Heiko will answer your question. There is a thread in the general questions area. He is on there at least a few times a week. He always knows the codes somehow.
Old 03-16-2017, 01:47 AM
time4a911
time4a911's Avatar
Would someone kindly do me a favor?
I have tried to sign up for Renntech seceral time with different emails, however I cannot receive the link to confimer the account activation.
Long story short, I need the radio code for a radio I purchased from eBay.
thank you in advance to anyone that can help by posting my request on RennTech
Old 05-21-2018, 08:17 PM
chris1251
chris1251's Avatar
Default Lost Radio help
I lost the radio code for my Porsche Boxster 2002 Serial # 15007972 CDR-220. Any guesses is appreciated!
Thank you,
Chris
Old 06-12-2018, 02:09 AM
aclt993
aclt993's Avatar
lost radio code cdr-220
Model # 4462
Ser.3 15007147
Thanks for your help
Old 06-12-2018, 11:21 AM
paulofto
paulofto's Avatar
Default try '986Forum.com'
Look for threads by a user named Heiko. He is the radio code guru at 986Forum.
Old 02-23-2019, 07:04 PM
zady mendoza
zady mendoza's Avatar
Default Radio code
I need help with my radio code for my boxster Porsche. I bought it from second hand.
Serial number is V5008201
Old 08-04-2019, 11:58 PM
tlbguardsred
tlbguardsred's Avatar
Default Need Radio Code Please
2000 Boxster S, Becker CCR220
serial # Y5040570
type 4462
Old 07-17-2021, 11:31 PM
Lepriconn
Lepriconn's Avatar
Default Cdr 220 code
I was hoping to possibly be able to get my code, recieved the car without any paperwork. I was able to get the serial number through the radio still.
Ser. W5002698
CDR 220
Type 4462
Thanks hope I can get some help.
Quick Reply: Need radio code
