K&N fries another MAF
Despite plenty of advice to the contrary, I recently decided to replace my stock air filter with K&N. It has been about 2 weeks (with 1 autocross) and now my check engine light is glowing like an amber "I told you so." I am taking the car to the shop in a couple days and will clean the sensor tonight.
Is there anything I can do to reduce the likelihood of this happening again (aside from putting in a stock filter and admitting defeat)? For example, I was thinking about briefly running a hair dryer on low setting over the filter to remove the excess oil. Has anyone experimented with this?
Any input is appreciated. I have not noticed any difference in sound or power since installing the filter.
Hair dryer is an interesting idea.
Just try not to over-oil. I have used one K&N filter for over 10 years. I don't think any Pcar owners have shown any dyno proven benefit to K&N. Paper filters are generally preferred.
If/when I have to get a new MAF for my car, I will probably go back to paper filters. But for the time being, I don't have much to lose by taking the same risks I have taken for the last dozen years. Good luck.
If K&N (probably due to overoiling) cause of MAF problem..
Frankly -- just changed my stock filter -- as dirty as this thing gets I'm willing to sacrifice a bit of air flow for better filtering, not that I think the stock filter is restrictive enough to have any impact on engine output.
Years ago when I used K&N on my motorcycle the trick was to use little oil and apply it several times with filter left sitting in various positions to help oil disperse.
IOWs, you have to sneak up on the proper amount of oil, unless you're gifted with ability to apply the correct amount once.
If filter overoiled, just clean it and let it dry then reoil with less oil the next time.
Sincerely,
Macster.
I have several K&Ns for my S. I rotate them into service allowing plenty of time in between for the initially moderate oiling to permeate fully. A systematic an even application helps the overall outcome. Never any problems.
Took it to the shop and confirmed that it was probably the MAF. Check engine light has not come back on in nealry a week, but I expect it will be back anytime.
