Boxster & Boxster S (986) Forum 1996-2004
MOMO Steering wheel install
Old 02-14-2008, 02:03 PM
70RSR
70RSR's Avatar
Default MOMO Steering wheel install
The car is an '03 Boxster S. Has anyone installed an aftermarket steering wheel like a MOMO and still gotten the horn to work properly? It does not look like the MOMO hub will let me use the horn without a lot of modification. I know I'll have no airbag. I would like to have the stock horn set-up.
Thanks,
Dave
Old 02-14-2008, 09:30 PM
boggtown
boggtown's Avatar
The horn should just be some wires. And a MOMO steering wheel should have a built in button depending on what model you got. You also need an adapter hub. Be aware your airbag light will be on after this.
Old 05-02-2009, 01:31 PM
Coochas
Coochas's Avatar
Interesting to see this post.
I literally just installed a Momo wheel in my 986. While I used my Bentley manual to the best of my abilities, when I got to the airbag wiring, I basically had to cut the wires going to the hub that the airbag/wheel attaches to. I have no idea how I can use the wiring to properly attach to the horn. I plan on bringing it to my local P-performance shop (Autobahn) and see if they can help. In the meantime I have no horn!
Old 05-24-2009, 11:26 PM
ericinboca
2nd Gear
ericinboca's Avatar
I'm preparing to install a momo wheel, with momo adapter and the teqnik quick release in my 04 986S. The parts have not arrived yet - but I took the stock wheel off today.
My question - what do you do about the black airbag sprial spring thing? It has the steering angle sensor attached to it. Does the adapter accommodate this somehow?
Old 05-25-2009, 09:27 AM
ericinboca
2nd Gear
ericinboca's Avatar
sorry guys - studied this more and realized it is not steering angle sensor - all airbag stuff.
Old 07-12-2009, 08:35 PM
rob76turbo
rob76turbo's Avatar
You guys may want to ping 986forum or Renntech to see if anyone else has done this.
Old 07-12-2009, 09:14 PM
Coochas
Coochas's Avatar
While I wouldn't call this "without a lot of modification," I relocated my horn button to the dash: https://rennlist.com/forums/boxster-...-the-dash.html
Old 10-15-2012, 08:07 PM
matthewbounds
matthewbounds's Avatar
Do you loose the clock spring when you add the steering wheel?
Old 10-16-2012, 02:58 PM
ToSi
ToSi's Avatar
Look at this thread (9*6 & 993 use same airbag / horn / wiper / switch wiring) -> https://rennlist.com/forums/993-foru...ng-photos.html
Particularly, the MOMO hub details on pg2..
For the 993rs wheel, there's a slight difference in the thickness of the hub vs the original 4-spoke. You'll need an extra M14(?) washer. Here's the final result:
Old 10-16-2012, 09:51 PM
trygve
trygve's Avatar
Is that the thing that turns off the turn signal after you turn? I've wondered why mine no longer turn off now that I have a detachable wheel/hub combo.
Old 10-19-2012, 10:47 AM
matthewbounds
Yes it is.
Quick Reply: MOMO Steering wheel install
