SCCA SSM autocross prep
Old 05-08-2014, 03:59 PM
jjwood
jjwood's Avatar
Default SCCA SSM autocross prep
I'm wondering about prepping my old 911 widebody for SCCA - SSM. Any comments or suggestions?
Old 05-09-2014, 09:37 AM
burglar
burglar's Avatar
I'm not SUPER familiar with SSM, but there's enough freedom in the rules to go pretty nuts. I pretty sure most smaller cars could be reasonably competitive with enough $$ and development thrown at them. I think the hardest part for SSM guys is keeping the cars from breaking.
Here's Carter Thompson's SSM winning rx7 from SSCA nationals. I've seen this car run, it's pretty insane. I've also seen the S2000 that Marc Pfannenschmidt is just getting together run, and that thing looks terrifying.
A 911 was entered and came in 17th and 28th. If you can find contact info for Paul Dornberg he might be able to give you some wisdom for a starting point:
Old 05-09-2014, 01:42 PM
jjwood
jjwood's Avatar
Thanks Burglar! Yes I'm in contact with Paul D. Looks like big aero + big wheels would help!
Old 05-09-2014, 04:19 PM
Earlydays
Earlydays's Avatar
The RX7's are running 3, or 4 rotor engines....
Old 05-09-2014, 09:10 PM
kjchristopher
kjchristopher's Avatar
Eric's black car is three rotor. I doubt Carter's is - looks two rotor. Andy's red car (now blue and running in XP) was two rotor.
I've built one of these on paper. I would not be going the direction that Paul went. Wouldn't use a wide-body, either. One of the car's strengths is its track. I'd look for 275s, possibly on a 15" wheel. Get down to 2200 or less and 350ish hp.
Old 05-12-2014, 12:56 PM
XPC5
XPC5's Avatar
I've seen both of the SSM rx7's evolve over the years, and watched many other contenders (including a very strong drive last year by Steve Hoelscher in an MR2 turbo). 300+ hp is a good target, gear for about 65-70 in 2nd. Use light flywheels, wheels etc to help with acceleration. Excellent handling and grip is a must. Even the lighter cars (2000-2500lbs) are running 275, 285, or 315 width tires on 10-12" wheels.
Old 05-12-2014, 05:15 PM
PedalFaster
PedalFaster's Avatar
It's not a Porsche, but here's a good blog outlining what it takes to build a nationally competitive SSM car: http://www.destinationssm.com.
Old 05-13-2014, 01:11 AM
kjchristopher
I'm suggesting 275s to get the 200# weight break. If you can't get down to minimum, you could consider going wider.
Old 10-19-2014, 11:01 AM
cturbo28
cturbo28's Avatar
I think a good old school 911 ASP set up would work excellent in SSM minus the engine prep. If you could get a good honest 300-350 Hp out of a NA 911 that would be very competitive in SSM. My experience is low in the flat 6 world since I mess with magic triangles. Not sure on the weight rules. I would research that first.
Old 10-20-2014, 08:42 PM
Earlydays
Earlydays's Avatar
I also think a 914/6 would be "wicked" in SSM
Old 10-21-2014, 11:53 AM
burglar
burglar's Avatar
Looks like maybe it'll be SM instead of SSM. Not sure how that plays out within the rules. From yesterday's release of the Nov Fastrack:
EDIT: Whoops, shows you how much I read the SM rule set. On the exclusion list for SM it still says "Porsche: All." So it would still have to be SSM.
Old 12-25-2014, 03:33 PM
S1MPSONS
S1MPSONS's Avatar
Subscribe for SSM talks. It would be cool to see more SSM 911s in the field. Build one.
Regarding RX7s, they are all 2 rotor except Erik/Beth. 4 rotor would be XP.
-Jake
SSM
93 Mazda RX7
Quick Reply: SCCA SSM autocross prep
