Audio and Video Forum The place to discuss auto and home audio, home theater etc.
Sponsored By:
Sponsored By: Musicar
Add aftermarket sub and amp to 2016 cayenne
Old 04-27-2015, 05:59 PM
anandjs2
3rd Gear
anandjs2's Avatar
Default Add aftermarket sub and amp to 2016 cayenne
I searched through the threads and couldnt find any info on this.
Just got my 2016 Cayenne and as I painfully realized its all fiber optics. Its got the Bose audio with the little puppy sub in the wheel well which is good for nothing. I have a JL 5 channel amp and JL sub that I was hoping to put in there. Would love to swap out the stock speakers as well, but I could live with it for now. I did find from some other thread that instead of playing around with the fiber optics, it might be easier to tap into the analog cable going into the bose sub and run it into a Line out Converter (LOC) and into my JL amp. Question is, could this be done?
How about the remote turn on? which wire could I use for that? The studded box in the pic is stock amp for sub. Connector on the right is input into the entire sub/amp assembly in wheel well. Connector on left is input into the stock amp and output (red/green) into sub. The cables doesnt look fiber to me. If they are analog, is it right to assume Orange and black is +-12V and can I use the same to power my JL amp without blowing a fuse. What are the purple, yellow and white wires? I know two are signal and one prolly remote turn on. The red/green cable is output into the stock sub
Please, any advise on how to wire with minimal mods would be highly appreciated.
Old 04-29-2015, 03:54 AM
veleno
veleno's Avatar
Usually the Bose speakers are like 8 or 2 ohms and are not compatible with aftermarket amplifiers. Best to get a LOC and run new wires to the doors with new speakers. While you're at it, might as well upgrade to a newer head unit. However, there may be upgrades to the new Bose systems that allow what you want, so it's best to check a competent and trusted stereo shop.
Where are you located? Maybe I can direct you to a trusted installer.
Old 04-29-2015, 04:10 PM
anandjs2
3rd Gear
anandjs2's Avatar
Thanks for the response. I'm not looking to swap the door speakers... just want to replace the bose sub & amp with my own. The housing is in the spare wheel well, I just couldnt figure out the wiring. I know I can tap into those wires in the pic and run an LOC, but how?
I'm located around Queens/Long island, NY area
Old 04-30-2015, 08:23 AM
veleno
veleno's Avatar
Sorry, I don't know any installers in the NY area.
However, you might want to call and chat with David to see if he can offer you some advice or if any of his LOC will do what you want. He is suppose to make the best LOC.
http://davidnavone.com/
Quick Reply: Add aftermarket sub and amp to 2016 cayenne
