PDCC major problems.
I was driving recently and got "Chassis system warning" message which wouldn't go away after shutting the car off. I went to the shop and first they found that the pressure in the system was too low. They said that it must be the pump which needed to be replaced, but after that they found a leak in the system.
Pipes (955-359-12300/12400) which lead to and from valve block were leaking. Well, they replaced those valves and the leak was gone. They added the oil which leaked out and said everything should be ok.
After driving for like 2-3 minutes the error message appeared again. I got back to the shop and they connected it to the diagnostic module again. The module has some kind of test for PDCC which tests all the stabilisers and checks the pressure i suppose. Well, in about 1 minute after the start of the test we saw thick smoke from under the hood - another pipe started leaking badly. Now i have to replace these: 955-359-11700/11501.
The guy told me that from now all the weak parts of the system will go bad this way until only the strong parts are left and these pair of pipes might not be the last.
Are we missing something? Is the problem really in pipes or maybe in pump or in valve system which puts uneven pressure into the system which breaks all the pipes? This is very strange to me. Before the second pair of pressure lines started leaking, it was clear on diagnostic computer that two sides (front left and rear right) had pressure much lower than the other two. Now, at that point of time, there were no leaks and the pressure should be ok, provided the other pats of the system are ok. The guy said that uneven pressure might be because of the air in the system which should had been bleeded out first.
So.. i am confused. Anyone had similar problems?
No pics unfortunately.
The guy at the shop said there could be several reasons why the error codу is still present:
- Air in the system. Since only two of four stabilizers are low on pressure, this seems kinda likely.
- Bad pressure sensor. But i doubt that two sensors can go bad at the same time.
- Bad pump. But is it possible that only two stabilizers are low on pressure whith inefficient pump? How could it be that there is enough pressure on two of them and not enough on the other two?
But i am still very confused on why lines explode. Guy at the workshop says that it could happen any time. But... Is it possible to run the test incorrectly so it creates too much pressure which kills the lines?
Has anyone even heard of this problem before?
I've never seen this problem before. I have replaced PDCC lines on a Panamera, and recall doing the bleeding procedure afterward using the PIWIS2 scan tool. I suspect that if the lines weren't bled, it could possibly overpressurize parts of the system.
This is my guess as well. Well, i hope that the pump, valves and sensors are all ok.
Otherwise this is very strange for two lines to explode in one day. Guy at the workshop says that during the test the pressure is slightly higher than it is while daily driving, so all the weak links are exposed. But... Still very strange.
I am considering suing the workshop for not bleeding the system and tus causing explosion of the lines. Where can i find some kind of an official document which states that bleeding is a must?
It would be in the workshop manual, which unfortunately, I don't have access to anymore. If your local dealer is cooperative, they can print off the procedure for you, but they really aren't supposed to. The 2003-2004 manuals are available from Porsche in print form, but they aren't cheap.
Okay,I got my pressure lines replaced and the "visit workshop" message appeared again.
The error code is 15627 and it says the pressure is too high on the front axle (sp?).
Anyone have any experience? The tech guy thinks the problem is with the pressure sensor and is trying to diagnose further...
Eventually, I've learned that those pipes may go bad on their own and cause major inconvenience. I love PDCC, it really makes this car unique, but I wasn't able to drive this piece of unique engineering for like two weeks, while I was waiting for those pipes to arrive, as Porsche didn't have then here in Moscow.
After they had replaced the lines with new ones, they had to bleed the system a few times to let all the air out and only after that that nasty warning message stopped appearing.
It's been a few months since I had those problems and everything works fine.
I've had ongoing intermittent problems with the PDCC in an 09 CTTS. The error messages I get are "Chassis system faulty" in yellow and "Warning chassis system" in red. Both generally go away after restarting the car. First time at the dealer, they replaced leaking hose(s) and topped off the power steering fluid. The yellow message still popped up every now and again, and the next time they still saw some leaking around the valve block, so they replaced that. Now I still get the error message once every few weeks. I tried bringing it back in, but apparently the yellow message does not cause any codes to be stored so they were unable to reproduce it at that time. Thank God for CPO.
