CHECK ENGINE LIGHT. O2 LEAK
Porsche tech says one side of my AWE headers are cracked and he suggests replacement of both sides first and if that does not work then replace O2 sensor.
Thoughts?
Anyone want to sell me a used pair of 997tt AWE headers? If so call or text me at 210-601-4535
Thanks,
Tom
Thoughts?
Thanks,
Tom
Thoughts?
Thanks,
Tom
Thoughts?
Thanks,
Tom
I think there could be. I pulled the trigger on a pair of 997tt headers for super cheap that I can use in the meantime while I figure out if I want to take to a muffler shop and have them weld.
Also spoke with AWE and even thought I am not the original owner they have offered to help. Waiting on their options.
Prior owner unfortunately partially flattened the tube closest to the ground by probably going over a speed bump so there is some restriction there but I never noticed a drop in performance. While they are out I'll see if anything can be done with that.
Thanks,
Tom
That header took a pretty good hit. There's the crack but also the flattened area. A good welder could hack saw off the flattened section and then heat it up and hammer out the flattened area then weld the piece back on but this will cost you.
Given that much flattening and the crack I'd be severely tempted to bite the bullet and replace the damaged header with a new one.
