997 Turbo Forum 2005-2012
PCM Skips Radio Stations
Old 03-23-2017, 04:32 PM
earossi
earossi's Avatar
Default PCM Skips Radio Stations
The manual for the PCM in my car is very thick and complicated. I have not been able to find an answer to my issue. The issue is that the radio will automatically change stations. The tuner moves from whatever channel I have selected to a channel I've never selected. Then 5 minutes later the tuner returns to the original station I had selected. 15 minutes later, the tuner repeats itself.
This is either a malfunction or there is a feature in the PCM that allows for auto cycling of stations.
What am I missing here?
TIA
Old 03-23-2017, 06:01 PM
Feld
Feld's Avatar
Mine is goofy also it un mutes itself sometimes, I agree that the manual is not helpful. Let me know if you make any headway.
Old 03-23-2017, 06:17 PM
vettenomore
vettenomore's Avatar
Select "Audio", then hit "Set" and disable RBDS (RDBS?). The radio has a feature that moves to a news-available station when RBDS is on. Unfortunately, you have to go through this process each time the car is started.
Old 03-23-2017, 10:56 PM
TT Surgeon
TT Surgeon's Avatar
Your radio might be set on scan or seek, when you hit a station you like just hold down one of the buttons on the keypad until you hear a beep.
Old 03-23-2017, 11:32 PM
earossi
earossi's Avatar
It's not exactly Seek or Scan. It's like a ping pong ball. Station 1, Station 2, Station 1, Station 2.......etc. Regardless of which station I chose, it will go back to the same station (i.e. 1, 2, 1,2, 1, 7, 1,7, 1, 9, 1, 9 etc) Always goes back to Station 1!
Old 03-27-2017, 06:05 PM
earossi
earossi's Avatar
Default Problem Solved!
The skipping stations is apparently related to traffic reporting. In scrolling though the PCM screens, I went to the Audio screen, and there is a function entitled "Traffic report" that was checked for my car. I removed the check mark, and the skipping issue I described above in no longer there. The "traffic" function must have to do with traffic reporting for the PCM. And, since I purchased the car in Calif, the preselected "traffic" channel turned out to be some obscure FM channel here in Chicago.
Not to belabor the point, but I was never able to find any reference to this PCM function in the huge PCM Manual that accompanied the car. So, am not sure how the "traffic" check marked in Audio is related to my skipping channel issue. But, it now appears to be fixed.
Old 03-27-2017, 09:26 PM
TT Surgeon
TT Surgeon's Avatar
It's designed to scan for traffic updates.
Old 03-31-2017, 10:05 PM
earossi
earossi's Avatar
Chris,
I get that. But, how does that explain the radio's tendency to shift to the "traffic channel" and not return to my selected channel?
Old 03-31-2017, 10:20 PM
TT Surgeon
TT Surgeon's Avatar
That I don't know, but I rarely set it to traffic.
Old 04-04-2017, 01:05 PM
function12
function12's Avatar
This is the fix. RDBS with try to pick up the sub channel some stations broadcast. We use to have this really bad here in Houston with a few stations. What sucks is you have to disable this every time you start the car.
Quick Reply: PCM Skips Radio Stations
