997 Turbo Forum 2005-2012
Looking for Alignment Spec Recommendation
Old 03-17-2017, 08:16 PM
skyak
skyak's Avatar
Default Looking for Alignment Spec Recommendation
My new Sport Cup 2's were installed today. Tomorrow I have an appointment to get an alignment. Any spec recommendations would be appreciated...or should I just stick with stock?
No track, just spirited dry weather driving. Thanks!
Old 03-17-2017, 10:58 PM
bondjockey
bondjockey's Avatar
Running negative camber of 1.5 or above makes a big difference in handling but stock components make that impossible. You need gt3 front lower control arms or camber plates. I am running -1.9 front and -1.7 rear and love it. If you track the car then you can be much more aggressive (-2.5 or so).
Old 03-17-2017, 11:12 PM
earossi
earossi's Avatar
It should be pointed out that running negative camber will accelerate wear on the inside of each tire. But, it will improve your cornering ability.
Old 03-18-2017, 02:34 AM
nzskater
nzskater's Avatar
I'm running -1.3ish up front with lowering springs, and -1.6 rear. Even with this setup I wear the outside shoulder quicker than the inside due to track days.
Old 03-18-2017, 03:13 PM
skyak
skyak's Avatar
Thanks everyone...got the alignment done at my local P dealer and went with the factory set-up for now.
Quick Reply: Looking for Alignment Spec Recommendation
