Agreed Value Insurance?
Nope...Regular coverage. Value comes in only in the event of a total loss. Otherwise things are replaced per any policy.
Valued policy for unique cars, and only applies in case of a not repairable vehicle. While these are nice cars, they do not require Valued policy....But do what you are comfortable with...
Also good to fully understand the valued policy and not assume you can just pick any number. You will also pay a higher premium in most cases....Just FYI
Do what you feel is warranted for you personally.
DC
DC
I just received an agreed value quote on 2007 997 TT from Hagerty. If you are not on agreed value policy you can expect NADA retail or very close to that should something happen to your car on a standard policy like a theft or total collision. To give you example NADA says my 07 is worth $58,480. I cant replace it for that, so therefore the agreed value policy makes sense. I dont believe Hagerty will accept the 997TT if that is your only car on the policy, you may have to have more than 1 car. Call and check. There is also Grundy and Leland West, but I have never used either.
May have to pull this car off our main policy and put it on a separate policy.
