Did the door sill wrap tonight.
It came out better then I thought.
I have a factory carbon wheel and ebrake so I diecided to wrap the sills in carbon instead of painting them.
You did a nice job. Looks sharp.
This is what I used.
A blow dryer works well make you heat is good when you doing the edges and I left about 2cm one the back side
you can't really screw it up if you have air bubbles just add a little heat and work them out.
Nice job! Which wrap did you use? Since I don't have any other CF, I think an OEM looking wrap would best for me? Any special prep needed? Any tips? Thanks in advance!
It's pretty straight forward the wrap is forgiving I used cf because the steering wheel and other items are cf if not I would of went factory.
I used a bit of brake cleaner on a cloth and wiped the parts down.
Only tip is do not over heat it and stretch the wrap too much I think if you do it there will be too much tension and it will start to peel
i posted the wrap I used in previous reply it's from amazon.
