oil change tip ...
I use a couple of cheap plastic ramps from walmart. Back the car up on them. My driveway has a slight slope making it even easier. I wouldn't try without some sort of lifting on the rear.
Elite, is the filter tip O-ring necessary? My dealer told me it's not and he also looked up how many were sold and he said 2 in over 5 years. He also mentioned that the service guys never change it when they do an oil change...
Just paid $42 for oil n filter change at the Lexus dealer. And a wash and vac. Thought I was dreaming. Barely covered the drinks and snacks I consumed while I waited.
Ok, back to Porsche oil changes.
From what kevin has said, you should change this. it's an expensive little sucker and mine was still in ok shape, but I did it on my most recent change. Will likely swap it every 2nd oil change.
In the 996 Turbo factory manual this o-ring (and the large one too) is supposed to be replaced every oil change. I always replaced these o-rings when I did the oil changes the techs replace then when I have the Turbo serviced at the dealer.
If you do the oil change you should replace both o-rings and if you have it done insist they both be replaced. If you have to insist the o-rings be replaced though I think you are using the wrong place to have your Turbo serviced.
