Where can I find a good grounding screw down near the fuse box?
Ran the wiring for my radar detector down to the fuse panel, I have a good source of switched power, but for the life of me I can not find a point to ground the circuit...The screws holding the fuse panel must be into plastic, and nothing else that's easily accessible is readily visible.
2008 997 Turbo
Help please!!
Thanks.
2008 997 Turbo
Help please!!
Thanks.
Pull the 2 or 3 phillips screws out that hold the carpet kick panel on around the fuse box, remove that. There are a couple body bolts under there that work for grounds.
