997 Turbo Forum 2005-2012
Got a leak, in need of radiator advice
Old 02-10-2017, 03:32 PM
Macster
Macster's Avatar
The relationship between wire diameter, wire spacing and opening size can be expressed mathematically as follows:
S = D + O
O = S - D
D = S - O
where:
S = Wire Spacing
D = Wire Diameter
O = Opening between the wires (Opening Size)
To Compute Open Area of wire mesh:
where:
A = % Open Area
D = Wire Diameter
Obtain the values from the mesh you are using and run the numbers through the formula above and calculate the reduction in surface area.
Some leaves/trash build up on a radiator while unsightly doesn't really cut down on the surface area all that much. I've pulled a lot of trash out of the in front of and between the A/C condenser and radiators and even though I was observing the coolant temperature using an OBD2 code reader/data viewer/logger there was no observable change in the coolant temperature.
Heck I've even had my Turbo lose a radiator fan -- fan motor shaft snapped -- and the coolant gage needle never wavered from where it normally resides.
The trash should be removed periodically more for concern about corrosion (and frankly odor) rather than any concern about its affect on cooling.
Old 02-10-2017, 04:46 PM
nzskater
nzskater's Avatar
Or you could install mesh, cut down the frequency of bumper removal for cleaning by 5, and significantly reduce the likelihood of any decomposition causing issues.
Sorry Macster, but no mathematical equation is going to weigh in against my real world experience - I've been running mesh for ages, done a lot of mid summer B road runs and track days and have seen no negative impact from having it installed. I have seen it save me from having to fish out birds, leaves, and rubbish, and would say it is a high priority mod for anyone driving in rural areas in autumn to prevent leaves building up.
And for anyone trying to hide CSF branding on a radiator
Quick Reply: Got a leak, in need of radiator advice
