997 Turbo Forum 2005-2012
Differential Failure - Whose had it
Old 01-12-2017, 11:33 AM
bigds01
bigds01's Avatar
Default Differential Failure - Whose had it
So the front diff on my 29k 2009 6mt failed. The car would lock up in reverse. It failed while I was driving slow on approach to the George Washington Bridge in New York.
No clue as the car has never been raced why it would have failed. Has anyone else had their's fail without a fluid leak? Any root cause analysis performed?
Old 01-12-2017, 11:56 AM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,226 Likes on 772 Posts
I had this problem on my 996 C4S, although it began to leak before failure. I never had any issue with the 997 TT.
If they approach the 997 repair the same way as the 996 repair, then the dealer will tell you that the entire front differential needs to be replaced. As I recall, the part alone is over $7K. My independent mechanic was able to rebuild my front differential for about half that cost. Hopefully you'll find a good solution for the 997 TT.
Good luck!
Old 01-12-2017, 11:57 AM
bigds01
bigds01's Avatar
I am just replacing the unit. It isn't a repairable unit. I sourced a very reasonably priced one.
Old 01-12-2017, 01:22 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
They said that the differential for the 996 wasn't a repairable unit either. It was repairable.
Glad you found one for a reasonable price!
Are you running wheel or tire sizes that are considerably different from OE sizes? Just curious.
Old 01-12-2017, 04:35 PM
bigds01
bigds01's Avatar
Stock wheels with sottozerro's for the winter. They drained the old diff today and metal chunks came out
Old 01-12-2017, 05:01 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Interesting... surprising that it failed like that.
Old 01-12-2017, 05:06 PM
bigds01
bigds01's Avatar
I have owned the car for 5k miles and it hasn't been hooned. I know the previous owner didn't either. Just weird. It was near the end of a 400 mile trip that day
Old 01-13-2017, 01:55 AM
CodeRed
CodeRed's Avatar
I would seriously consider deleting it altogether at a $7k cost to replace it
Old 01-13-2017, 09:26 AM
bigds01
bigds01's Avatar
Except the whole reason I got it was to drive in the winter
Old 01-13-2017, 11:39 PM
TT Surgeon
TT Surgeon's Avatar
One thing known to fry the front diff is out of spec tire sizes fr to rear. If your snow tires are more than 4% off that might be the issue.
Old 01-14-2017, 12:07 PM
bigds01
bigds01's Avatar
295's on the rears
Old 01-15-2017, 01:05 AM
TT Surgeon
TT Surgeon's Avatar
It's diameter of the front to rear ratio what's important, I bet you have a greater than 5% differential fr to rr vs stock.
Old 01-15-2017, 08:22 AM
bigds01
bigds01's Avatar
The front's are 235/35/19 and the rears 295/35/19 Sottozerro II's . Would that cause an issue?
Old 01-15-2017, 09:53 AM
fresh-popcorn
fresh-popcorn's Avatar
Aren't the rears suppose to be 295/30/19 and not 35?
Old 01-15-2017, 01:42 PM
Harry Da Hamster
Harry Da Hamster's Avatar
Weird you had this issue. I'm thinking some sort of neglect from the previous owner. Perhaps he had a spare of some sort on a front wheel? Or ran one of the two tires pretty low and continued to drive? Or maybe you're just the statistic...?
Quick Reply: Differential Failure - Whose had it
