What Voltage are you seeing from Alternator?
Hi All,
Wondering what voltage people are seeing from their alternator with the car idling...
My understanding is that over 14.4 volts means the voltage regulator is no longer functioning correctly. Using a voltmeter on the battery I have recently observed a range of voltages on my 07 turbo, all greater than 14.4 volts. The highest voltage (~15 volts) was during a cold snap, and it seems like the colder the temperature the higher the voltage. I have an appointment set up to replace the alternator (apparently on our cars you can not just replace the voltage regulator), but would be interested to hear what voltage others have seen...or if anyone else has seen this issue.
Hi All,
Typically the battery voltage will be high after a start, and especially a cold start, in order to recharge the battery. The voltage level at the battery drops over time as the battery gets topped up and the amount of volts routed to the battery is reduced.
Also, if additional electrical load is enabled -- the lights are turned on, the A/C system is turned on -- the battery voltage drops some as some electrical power is instead of being routed to the battery is routed to the car's electrical system to meet the increased electrical demand.
Given the cost of replacing an alternator in one of these cars I'd want to be darn sure it needed replacement.
Hi All,
Voltage regulator can fail that you dont get enough voltage or too much.
You can def see 14.8 -14.9 when a/c radio etc is turned on. and snapping the throttle will draw for more amps making your voltage go up.
Has your gauge been moving up and down? battery light?
The measurements I took were at idle only. I have not had any dash warning lights. It just seems to me that the voltage regulator should never allow over 15 volts if it was working properly...
also is your battery strong?
