Will these center lock wheels fit a 2012 TTS
Any ideas If these will fit a 12 TTS with center locks
8.5 X 19 ET 53
12 x 19 ET 63
They're for a GT3
Thanks JB
From this site: http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
Inner Clearance (the inside of the wheel to the strut housing): 25mm LESS
Outer Position (position of the outside edge of the wheel): EXTEND an extra 1mm
From those results I'd suggest you'd need a 25mm spacer to prevent any inner conflicts/rubbing. Don't quote me on that though as I'm unsure if we can push a wheel out by 26mm.
I forgot to mention these are for a Center Lock fitment...which would rule out spacers I would think.....right???
This is the OEM CL Wheels Specifics...on my 997.2 TTS.
8.5JX19" Offset: 56mm
11.0JX19" Offset: 51mm
My goal is to stay with 19's push a wider wheel/tire or offset to the fenderwell lip...and lower the car..
With my 997.1 5 lug, I had options, w/ these C/Ls I need to nail the combination.
I really don't want to drop a ton of $$$$$ and used wheels are fine...but really would like to know from someone's personal experience what will work...without issues.
This pic is from an RLer...the wheels are 20...but the fitment I'm searching.
Thanks JB
Thanks JB
With my HRE 590RS they are a perfect fit for the 997.2T with CL. Offsets are dead on and fill the wheel wells perfectly.
Even in 20", due to then lips, they look perfect on the Turbo.
My specs are:
Sizes and Offsets: 9x20 et. 53mm & 12x20 et. 48mm
My specs are:
Super Helpful...thanks!!!
"You're feeling very sleepy, your eyes increasingly becoming heavy." "That's right, you're in a deep, deep, sleep..." "Now, unmount your wheels and ship them to JB in NC...also, cook your dog a filet mignon ...."
Amigo, this is perfect... I'd rather not lower the car, so the pics are a huge help. Big thanks!!! JB
I think the fronts can come out more, the rears with a 325 is flush, can maybe come out an additional 5mm, never tried.
I'm on stock fenders, no roll. Lowered and never rubbed.
