997 Turbo Forum 2005-2012
-Build Thread- 997.2TT PDK by Esmotor
Old 11-30-2016, 03:18 PM
Domer911
Domer911's Avatar
the OP is serious
Old 11-30-2016, 03:21 PM
3llooi
3llooi's Avatar
Originally Posted by Domer911
the OP is serious
What's OP?
Sorry if it's a silly question lool
Old 11-30-2016, 03:41 PM
El Dario Loco
El Dario Loco's Avatar
Originally Posted by 3llooi
What's OP? Sorry if it's a silly question lool
Its you 😊 =original poster. Agree, most serious 👍🏻🙏🏻
Old 11-30-2016, 03:47 PM
saabin
saabin's Avatar
What's OP?
OP = Original Poster.
In this case, you.
Old 11-30-2016, 04:07 PM
3llooi
3llooi's Avatar
LooooL
Ok
Yeah.. I am I guess
Old 11-30-2016, 06:42 PM
3llooi
3llooi's Avatar
Progress report number 8, 30 Nov 2016
so today I didn't have much time to work on the car ( as usual :)
I've focused on the fitment and installation location of the methanol pump and tank
I was quite happy with the plan and results.
I'm liking the trunk mat more lool
​​​lool
Little idea to have led strips beneath the tank to easily see the level. I'll wire it to the trunk bulb to activate when the trunk is open
Stripped the paint of the supplied tank braket. Will spray it black
Old 12-07-2016, 08:42 PM
3llooi
3llooi's Avatar
Progress report December 7th, 2016
as usual , I've been busy with work and travel.
good news I was able to do some work
1. Finished up the engine bay side install for the methanol injection , I fixed the FAV and hoses
2. On the trunk side I have installed a small fuse box and ran all the wiring for the methanol pump... plus a little tweak that I thought would be useful; which is a three port panel to monitor voltage , 12V port and USB ports... I'll also use it to hook up the battery charger
3. I forgot to paint the tank braket earlier . . so I sprayed it with a truck bed liner that comes in a can . .. nice stuff !
Added an edge rubber thingy... not sure about it though
Old 12-08-2016, 05:09 PM
3llooi
3llooi's Avatar
Program update , 8th Dec 2016
had fun today to see things coming together
1. I've completed the wiring on the trunk aluminum mat and hooked up the plugs for the methanol pump and hoses of the tank
2. mounted in the car
3. ran the pump on battery power to test with water in the tank for any obvious issues
Old 12-12-2016, 01:05 PM
3llooi
3llooi's Avatar
Progress report December 12th, 2016
today is my birthday
today the focus was on the ECU.
I've remove the steel tray holding the ECU. disconnected the plugs and stripped the wrap on the harness.
identified the wires by color according to the Aquamist supplied diagram.
it went smooth.
I used posi taps and added a little thicker gauge wire to connect the taps to the Aquamist insanely thin wires.
Old 12-27-2016, 03:27 PM
Ammein
Ammein's Avatar
Nice !! Any updates with the build so far?
Old 12-27-2016, 04:56 PM
3llooi
3llooi's Avatar
My bad!
I was actually updating the thread on another website
I forgot to update this and add the performance results.
Old 03-17-2017, 04:46 PM
Kevin
Kevin's Avatar
Any updated 60 -130's
Old 03-17-2017, 06:23 PM
3llooi
3llooi's Avatar
My best so far is 5.3s
And 100 to 200 kph is 4.6s
I believe I've a world record.
Old 03-17-2017, 09:04 PM
Kevin
Kevin's Avatar
Congrats...
Please share more of your info/results..
Old 03-18-2017, 01:25 PM
jazzwu
jazzwu's Avatar
Very nice! And you're still on the stock fuel system and clutch pack?
Quick Reply: -Build Thread- 997.2TT PDK by Esmotor
