997 Turbo Forum 2005-2012
Protomotive E85 tune, WOW!!!!
Old 04-15-2016, 08:42 AM
nuclearfishin
nuclearfishin's Avatar
Default Protomotive E85 tune, WOW!!!!
I just got my car back from the guys at P3 who converted my car to an E85 proto tune and all I can say is wow, the car has never pulled so hard. Daily drivability seems unchanged, but when you put the hammer down it goes. For comparison I'd been running a giac tune with race gas prior, and it doesn't even compare. I'll have the car at the track next week and will report numbers when I get them, but I'm confident the car is quite a bit faster now. Btw, I also had the proto tip software upgraded but haven't had enough time behind the wheel to test completely yet. E85 = highly recommended!
Old 04-15-2016, 10:52 AM
jaycm3
jaycm3's Avatar
awesome...did they need to drop the engine to do the injectors?
Old 04-15-2016, 11:37 AM
nuclearfishin
I'm pretty sure they did although I didn't ask them that specifically.
Old 04-15-2016, 11:40 AM
A418t81
A418t81's Avatar
Congrats. Told you it would be worth dropping the canned tune
Old 04-16-2016, 08:24 AM
El Dario Loco
El Dario Loco's Avatar
Sounds great! Is the only thing needed for the e85 conversion new injectors and tune? Can you still use regular gas or is it strict e85?
Old 04-16-2016, 03:12 PM
nuclearfishin
I had a 5 bar fpr added as well. I think you can only run E85 as the timing is advanced to the point if you run regular you might risk detonation. E85 runs really cool.
Old 04-20-2016, 02:47 AM
elite1
elite1's Avatar
Great to hear!
I look forward to your progress with your conversion to E85 and new tune.
You had solid times with GIAC and I would like to see your signature change with Pride!
Keep that clutch foot steady and consistent!
Old 04-20-2016, 03:56 PM
El Dario Loco
Very cool. Also interested in hearing what you think in the long run.
Old 04-22-2016, 02:34 PM
nuclearfishin
Originally Posted by elite1
Great to hear!
Thanks guys, I'll have it at the track Sunday and will report times. I'm still smiling every time I step on it. This past week I actually did an awd burnout, that's how much power it has now. Lol
Old 04-22-2016, 02:41 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,069 Likes on 1,181 Posts
Does this conversion include adding a fuel sensor so the ECU knows what percentage of ethanol is in the tank?
Is this re-turning the stock ECU or going with an aftermarket brain?
Old 04-26-2016, 11:17 PM
bigrpowr
bigrpowr's Avatar
i talked to todd there today, and he recommended injectors for the e85 tune, but he did say for the time being i could run a e85 file for stock injectors, its much more tame but should still be a high 500hp tune, which is more than i need ! he seemed to know his stuff !
Old 04-29-2016, 06:27 AM
Fishey
Fishey's Avatar
nuclearfishin we did both a FPR and Injectors for the E85 Tune.
Good to hear that its running strong!
Old 04-29-2016, 01:40 PM
nuclearfishin
You guys did an awesome job Fishey! I think I owe all you guys some pizza and beer for getting me down to a 10.5. :-)
Old 04-29-2016, 09:49 PM
bigrpowr
bigrpowr's Avatar
sounds like you guys did a great job. any idea how to swap injectors w/o dropping the motor ?
Old 04-29-2016, 11:11 PM
32krazy!
32krazy!'s Avatar
Lower the motor as far as it will go remove the fuel filter and sai and get ready to bleed a bunch
Quick Reply: Protomotive E85 tune, WOW!!!!
