Check engine light
Check engine light
Hi , am a newbie here and have a 08 Turbo. I was out in the countryside driving on a tour, when suddenly i started hearing a strange whistling loud noise from the engine. I also noticed that the turbo was not kicking in as well as before. I was more than a 100 miles away from home and broke away from the tour group and decided to drive back home. Soon after, my check engine light turned on and it reminded me to keep below 70 mph, which I did. I however drove the 100 miles back home. I am not a technical person with cars, but still would like to understand what are the probable causes ? From my own research on different blogs, it could be a vacuum leak . Any other opinions ? I just had done an oil change last week and drove just 5 miles since then, before i went on the tour. I dont know if that even matters in this diagnosis, but thought it may help.
Cheers
Cheers
Sounds like a boost leak. Check the pressure hose connections from the turbos through to the Y pipe, and the Y pipe to the plenum. You'll likely find one has come loose. Has their been recent work done on your car?
After visual check and some tug n pull, the only thing i found was one of the intake brackets was not mounted to the engine bay. The pressure hose connections all seem to be in place - nothing shaky or loose.
It's still likely one of the connectors that has partially come out. They are sneaky. They will look and feel like they are engaged, but aren't fully. It requires pulling the rear bumpers, wheels, etc to fully inspect and re-seat everything. Happened to me a couple of times before I threw it all out for and upgraded setup.
