PPI over rev count - Need help on understanding it.
Here's one simple way to think through the math...
If range 1 and 2's tend to represent hitting the red-line events, and 3+ tend to be money-shifts, looking at the 1's and 2's gives some (albeit, not perfect) perspective on how aggressively it was driven.
The rev count represents one ignition per piston firing. In a four-stroke engine, each piston fires once every other revolution. Accordingly, at 6,500 RPM's, which is approx red-line, each piston fires 3,250 times per minute; with 6 pistons, that's 19,500 ignitions per minute, or 325 per second. If the average red-line lasts a second, that's 325 ignitions per red-line event. Bear in mind all these rates assume 6,500 RPM's.
So if a car happened to be 7 years old and hit the red-line once a month, that would be 84 red-line events at 325 apiece, or 27,300 ignitions on the report.
Caveat: All of this is an over-simplification - at higher RPM's, there would be more ignitions per unit of time, and the ignitions wouldn't be evenly distributed across the rev range. And this says nothing of the money-shift math, but perhaps it gives some perspective.
NickS - good catch, though for whatever reason, mine looks like 6,500. In either case, the math (as amended above) is at least reasonably illustrative.
So a recent PPI on a 997.1 TT showed up these numbers. should I be concerned?
# of ignitions
1 - 13072
2 - 2318
3 - 391
4 - 99
5 - 5
6 - 1
Operating hours@
1 - 1299hrs
2 - 1299hrs
3 1257 hrs
4 1193
5 1193
6 251
total hours 1307
dont those numbers seem kinda high?
# of ignitions
1 - 13072
2 - 2318
3 - 391
4 - 99
5 - 5
6 - 1
Operating hours@
1 - 1299hrs
2 - 1299hrs
3 1257 hrs
4 1193
5 1193
6 251
total hours 1307
Received 5,388 Likes
Can you buy a powertrain warranty as a hedge? Personally, I'd pass.
