997 Turbo Forum 2005-2012
Crazy fast 997.1 turbo on stock VTGs
Old 02-20-2015, 12:30 AM
jazz997tt
jazz997tt's Avatar
Default Crazy fast 997.1 turbo on stock VTGs
Not sure if any of you guys have been following but this to me is SO impressive!
http://www.6speedonline.com/forums/9...ptf-tuned.html
I want this setup on my car. Anything faster would just be ridiculous!
Old 02-20-2015, 08:48 AM
CincyScott
CincyScott's Avatar
Glad to see the platform doing so well. I don't ever see myself doing E85, but it sure seems to produce results.
Old 02-20-2015, 11:24 AM
jazz997tt
jazz997tt's Avatar
It boggles my mind how much performance is available with E85, some bolt on modifications and customizing the tuning on the 997.1 even before changing turbos for aftermarket ones. This is Veyron territory people!
Old 02-22-2015, 03:42 PM
phillipj
phillipj's Avatar
I would do the E85 but there is not enough stations near me to make it a viable option.. Too bad because like you said great power. It's like running 110 or higher octane.. You just need 80lb injectors..
Old 02-22-2015, 03:59 PM
Stage7
Stage7's Avatar
Too bad its impossible to run e85 on the 997.2 currently.
I really hope someone figures out the fuel system on the dfi cars soon. Is anyone even trying? I know Champion was doing a lot of R & D years ago.
Has everyone given up?
Old 02-22-2015, 04:37 PM
Team Plutonium
Team Plutonium's Avatar
Originally Posted by Stage7
Too bad its impossible to run e85 on the 997.2 currently. I really hope someone figures out the fuel system on the dfi cars soon. Is anyone even trying? I know Champion was doing a lot of R & D years ago. Has everyone given up?
What are you talking about? Of course you can run e85 on the 997.2. Upgrade fuel pump (easy mod), and run a specific e85 map. If you run it more frequently (doubtful since e85 is hard to come by, at least in my area) you should upgrade your fuel lines. I'll probably run e85 at my first race this season in April.
Old 02-22-2015, 05:56 PM
Stage7
Stage7's Avatar
Would you mind posting a link to the fuel pump upgrade for the 997.2 turbo?
Old 02-22-2015, 06:21 PM
Team Plutonium
I'm going with Walbro:
http://mail.ituner.net/store/product...anufacturer=61
Once all my mods are here I'll most likely start a build thread as we put everything together.
Old 02-22-2015, 06:39 PM
jazz997tt
jazz997tt's Avatar
I asked Dzenno from PTF about this and he said while you can run E85 on the 997.2 and tune for it the factory fuel system can't supply enough fuel. If it was just an in tank fuel pump swap away I'm sure we'd see it a long time ago. DFI is a different beast from old school on the 997.1. I heard they're working on it though.
Old 02-22-2015, 06:47 PM
Team Plutonium
Hence upgrading the fuel pump and lines.
Old 02-22-2015, 06:53 PM
93ls1rx7
93ls1rx7's Avatar
You sir are drunk. Those fuel pumps will not work with a 997.2 DFI motor. Those fuel pumps have a pressure output of about 45 psi, your issue is DFI motors inject the fuel into the combustion chamber at 3000 psi.
No one has figured out how to increase fueling for the dfi motors yet.
Champion has talked about it for years, bmw guys have been trying for years. Only solution available is putting in additional injectors but I haven't seen anyone do it on a Porsche 997.2 yet
phillipj
phillipj's Avatar
I have the Protomotive tune on my 997-1. I was interested in getting an E 85 map. According to Todd at Protomotive the only modification necessary to run E 85 is the map and 80lb injectors. There is no need to change fuel pump or lines.
Like I mentioned. There is E 85 available near me but not "near" enough lol!
And Plutonium.. Can you shed some light on your avitar?
Old 02-22-2015, 06:56 PM
Team Plutonium
Yeay, I'm looking at different injectors as well. I have easier access to race fuel, so I'll mostly run that map. The nearest station for e85 for me is 60 miles away.
Lines are really only necessary if you run it all the time, which most people don't anyway. But if you run it on a regular basis I'd switch out all the rubber connections.
Avatar: Christian Bale from American Hustle - love that movie!
Old 02-22-2015, 07:02 PM
93ls1rx7
93ls1rx7's Avatar
I would love to see the direct injection injectors you are referring to as well.
Old 02-22-2015, 07:13 PM
Team Plutonium
Upgraded 80lbs Bosch injectors should do the trick.
Quick Reply: Crazy fast 997.1 turbo on stock VTGs
