The Blackstone Labs Oil Report Thread
#31
Received 5,388 Likes
Great tips & advice from Kevin! Thanks.
#33
#35
The holy grail for engine oil is to "find" a oil that freezes your engine wear. The factory 0W40 sheers.
Race oil, Motorcycle oil AND heavy equiptment/offshore marine diesel engines are exempt and can keep the zinc and phosphorous metal conditioning agents. Go to the Mobil 1 website. They are now recommending the Motorcycle Mobil 1 VTwin oil for Porsche aircooled engines. It is a GREAT oil and reverses the metal wear numbers! I have seen it. The problem for us is>> the viscosity is 10 points to high since it is a 20W50 oil.
http://www.valvolineeurope.com/engli..._racing__5w-50
#36
Registered User
There is a new viscosity for Valvoline VR1 syn, that oil has a ZDDP level of 1300/1440 PPM it seems and should be perfect for our cars, thoughts ?
#37
I believe Valvoline VR1 5W50 could be just what we need.
In my search I stumbled on this test :
http://www.animegame.com/cars/Oil%20Tests.pdf
Look how well the Valvoline semi-syn performed. (and how poor MOBIL1 for that matter)
The full-syn VR1 5W50 high ZDDP level should be much better still and should outperform them all !?
#38
Agent Orange
I drove a lot this year... And the results look good. Switched to M1 5W-40 TDT at Kevin's recommendation, see how the engine responds. This is what came back after 7,000 miles on M1 0W-40:
#39
Ilko, I am confused. Did you actually switch to 5W40 TD? The Blackstone report notes 0W40 too. Thanks.
#41
#42
Thanks for posting Ilko !
Looks like 0-40 Mobil1 is a good oil for our engine after all.
And it also shows it's unnecessary to change oil at 3000 miles.
Take it to 9000 miles seems good advice looking at those numbers. Looks like you drained 'like new' oil
#44
Registered User
Heres mine, just got a week or so ago. Oil had around 6500 miles on it.
Mobile 1 0w40. Well see how it looks next time with the Motul oil.
#45
Nice !!
What stands out for me is the quality of the oil. They guesstimate looking at the sample you did 3600 miles while you did almost the double.
These reports clearly show modern synthetic oils last a long, long time.
I bet 12000 miles is not a problem.
What type of MOTUL oil did you use Jerry ?
