Skeptical of Softtronic ECU Reflash Claims
Jeff, everything in the Motronic 7.XX series ECU is handled thru a torque model and torque request. The input from the throttle is constant from non Sport to Sport mode. The difference is the requested load that changes. The ECU will increase boost and timing to meet that demand of the requested load. And yes, the throttle is the input source. But when you look at the datalogs you will see that your pedal is at 100% WOT on both modes.
The power levels between each mode is changed, it has to or you wouldn't pay for the Sport mode. The PEAK numbers don't change however the power or duration of torque is increased during the "time" in the Sport mode. Power under the curve is increased in that "time" frame/duration.
Edit.. For those that are interested, I will email datalogs from my car and other 997TT customers to see what is monitored and what the ECU is doing.
This is really an important and informative thread that should be read by anyone considering an ECU reflash. Many thanks to all!!! Based upon your posts and recommendations I've ruled out the plenum and will proceed with a Europipe exhaust, Softronic ECU reflash, and OEM plugs. That combo when combined with my Pilot Super Sports and updated Pioneer Nav shoud turn my TT into a very enjoyable car to drive.
BTW, I tracked my 500 hp 08 MB AMG Black Series at the Virginia International Raceway (VIR). And you're right, it really does come down to driver skill. I remember staying with a modified 800 hp twin turbo Audi R8. He pulled me on the straights but his 800 hp actually hurt his performance on the twisties where I easily handled him. It ultimately came down to driver experience and a properly set-up track car.
I'm also going to reflash my Cayenne GTS's ECU and will probably also go with a Fabspeed secondary cat bypass. Net result should be approximatley 20+/- bhp and tq accompanied by better throttle response. I don't want to go too wild as my GTS is a limited edition and I intend to occasionally show it.
This is really an important and informative thread that should be read by anyone considering an ECU reflash. Many thank to all!!! Based upon your posts and recommendations I've ruled out the plenum and will proceed with a Europipe exhaust, Softronic ECU reflash, and OEM plugs. That combo when combined with my Pilot Super Sports and updated Pioneer Nav shoud turn my TT into a very enjoyable car to drive.
However let me clarify the following, since you are going to do your plugs due to their age anyway, then consider the cooler plugs since they should last longer than the stock plugs with the new tune.
If your stock plugs were new or very recently changed then I wouldn't necessarily spend the money to change to cooler plugs right away
Just something to consider
Art
Thanks Kevin for the Info.. And 4ocious.. As Tom said DO NOT waste your time and money on a plenum, It;s total BS.. I had the plenum and GT3 throttle body. I went back to stock and wasted a bunch of money.
The best bang for your buck is the tune and an exhaust. Then learn to drive your car. Even if you have 800 hp a good driver in a Cayman will kick your butt. I you really feel you need to have an titanium exhaust then by all means buy one.. But it is not going to perform or sound any better than a Europipe.
2 Years ago I would have argued with Kevin about mods. But not anymore. We had a Lambo club here at the facility last Sunday. One of their friends had put a twin turbo set on a Gallardo. 1000hp.
It wasn't more than a week before he stuck it in a fence and destroyed the car.
550 hp is plenty. Especially if you know how to use it.
Good luck with whatever you decide but you have been warned. Stay away from bogus mods..
Yup a boxster last weekend at Laguna laid down a 1:41 lap, almost 7-10 seconds fast than cars with +200hp.
That sounds like a great combination of options and I think you'll be happy.
Art
Art
Some people keep there cars stock till the day they sell it ,but some of us just can't leave them alone ,i think the latter hang out here & on other boards as long as your happy with it thats all that matters ,myself i get used to the extra 50 hp & new wheels & want another 50 hp & new wheels
Reading with interest; as i am considering the same mods as 4ocious.
Question: Does all this extra HP cause significant wear and tear on other parts of the car? ie; are there other expenses to expect down the line( sans tires)?
I think the clutch is the first thing to replace after tuned power.
With a tune and exhaust your approaching the limits of the OEM clutch. Depending on the condition of your clutch you may or may not see slippage. Several guys are still running OEM clutches w/o issues. When the clutch does slip or go most will upgrade to a Sachs 2.5 kit. This runs anywhere from 1600-2500 depending on whether or not you want a new flywheel, labor not included.
btw here is the dyno chart that Vivid uses to market the softronic tune
From my calculations I get:
Base case assumption: Stock ECU (480 hp) + Free Flowing Exhaust (+20hp) = 500 hp at the crank
Dyno shows max 425 hp. Adjustment ratio for dyno loss: 500/425 = 1.176
Dyno for Softronic Tune + Exhaust produces max 491 hp: apply the dyno loss ratio calculated above (491 hp X 1.176) = 577 hp at the crank
570 hp is much more in line with what others expect to see with a tune + exhaust. As Phillip has pointed out his tuner has said ~550 hp is realistic to expect
so...
how does Vivid get to 615 hp? why would the stock set up have a 15% dyno loss but the tuned dyno run have a 20%+ dyno loss?
what am I missing?
so...
what am I missing?
^^^^^^^^ BTW I also posted this on Vivid's "Softronic March Sale" post on 6spd.
Hopefully Dan has a good answer
I love the real power gains with the Softronic Tune + EP exhaust, and believe me 570hp is waaaaaaaay more than you need on the street to enjoy these cars. I just want to clearly understand how they go from the 570 hp I calculated to the 615 hp they claim (I assume the dyno chart is real)
^^^Details on website contrdict the dyno chart. They claim 80hp gains to the crank with tune alone, so lets just say with exhaust you're at 580 crank. I'm okay with that number, however I was told the 615 was based on a 93 tune. The dyno chart above has 93 scribbled in. Either way I don't believe you can gain ~35hp from 91 to 93. Hopefully we get some details and as I've said before APR/FVD/Softronic etc and Europipe,Tubi,GMG etc need to have a shoot out using the same car under the same conditions.
At the end of the day It's really not important to me whether I've got 550hp or 570hp with this tune as I'm perfectly happy with the real world "feel" of the car given what I paid for the tune. It's more about understanding why the claim is 615hp, and if this claim is incorrect why it is it allowed to be perpetuated
- Art
