Home Link problems.
#31
Assume you are following the Homelink instructions as posted in their website - if so make sure when you go to the front of the car to pair the remote that you use a full size remote (not the mini) with fresh batteries.
#33
Did you also set the "learn" button on the opener at the same time? I just did this yesterday after I needed to clear the memory in all my openers for another reason.
#34
Finally took the time to really try and program my home link today. And yes it finally worked. For those who are still having an issue here is how I finally accomplished it. 1.) Clear any codes by pressig the outer 1 and 3 buttons simultaneously until the diode (to the right) starts to flash quickly. 2.) Then press the desired button you want to program until the diode begins to flash slowly. 3.) Hold tansmitter approx. 12 inches in front of bumper and press transmit button on remote until the daytime driving lights flash 3 times. 4.) Now press the "learn" button on the motor box of your garage door opener. A red indicator light will flash on the box. I had to use a ladder to do this and park my car just in front of the garage so that it would pick up the signal. Once the red learning light flashes get back in your car and push the same button that you are programing repeatedly until the garage door responds to the programmed button. I had to push my program button 4 times to learn the code, and have the garage door respond to the new signal. That was it. You will know if you have a "learn" button on your motor box. Most motor boxes that have a little wire hanging down from them are learn, applicable boxes. For those who have had a difficult time programming home link, try this. If it sitll doesn't work then call Home Link themselves to assist you. They have a 800 number on the internet to call. Jay
#35
Are you guys saying that I need to hit the learn button on the opener BEFORE the car learns the code and flashes the fog lights 3 times? I cant get the fogs to flash...
#36
Also, have you tried varying the distances between remote and front bumper - I think you said you were 2 inches away and even had the hood open - maybe try a little further back - book says 0 to 12 inches...and hold the remote button until the lights flash - should work but can be very frustrating.
#37
Mystery solved. I have a new garage door opener with the Internet connectivity. Apparently, I need a repeater as the new remotes are a different frequency than older versions of homelink support. My door opener is only compatible with Homelink 4.0 and above...
http://site.garageintel.com/LiftMast...822.1416163384
My door opener won't work with any of my 4 cars Homelink systems...
#40
Thank you DJ23 !
#41
Likewise i'd love to say thank you. I subscribed to this thread awhile back and used it 2 weeks ago to finally set up everything. Forgot to bump it up for the benefit of others.
The instructions in the Porsche owners manual weren't very good. This was a HUGE help.
#42
Rocky Mountain High
I just ordered two LiftMaster wall mount garage door openers. I've already ordered the repeaters because the garage door company told me that I'd need them.
#45
Thanks Jay
After a couple of days of thrashing around with the Porsche manual, no luck, was about to give up and go with the "clicker", when I came across Jay's post. I followed his instructions to the letter, and Presto! It works!!!
The only thing I would say is, I had to press my program button 7 times (Jay was 4) to get it to take.
The coup de grace was after I got it to work, I went to close the door one final time and it came down halfway and quit... The motor was so damn hot from all the work
Anyway, when approaching this task, you really need to be in a patient mood, and recognize there could be some frustrating set backs, just take another hit off the can of club soda and carry on
