Battery connection
Battery connection
Hello,
I decided to clean connectors to make make sure everything is fine with my newly replaced battery-cleaned posts to make sure, with the wire brush even though it's brand new.
I then traced the positive cable to where it goes just below the windshield below a wire harness. I haven't seen any posts on this connector-so I pulled the red tab which allows me to pull the cable off the post it attaches to. The reason I pulled it apart was I noticed the cable spins if you turn it. I thought it was loose but it is by design-I'm posting some
pictures in case anyone wants to make sure it's clean-it's a bit dark in the garage under the hood even with lights on but it gives you an idea 👍
